Air Drying in Arizona
Forum topic by KenBry posted 370 days ago 522 views 0 times favorited 8 replies Add to Favorites Watch
View KenBry's profile
KenBry
449 posts in 618 days
370 days ago
Does anyone have any experince drying green lumber in Az? I am considering trying to get a few downed trees and getting them cut and drying them my self. But I am wondering how the dry heat here affects things and so forth.
We have had several wind storms here and I thought I could gather some of those down tree trunks. There is always downed trees from one storm or another.
I have access to lots of Mesquite, euculiptus, jacarandia and odd things here and there.
-- Ken, USAF MSgt, Ret.
8 replies so far
View Nomad62's profile
Nomad62
567 posts in 1129 days
#1 posted 370 days ago
I had some black walnut logs, around 36” wide, sawn up after they had sat under cover for about 6 months and sent them to Nevada in the early springtime. I’m in NW Oregon. My brother down there let them set and dry for about a month then sliced them up and completely tricked out the inside of his home with it. Absolutely beautiful. But walnut is forgiving, and can put up with stresses other woods cannot. This is getting pretty late in the year to send wet wood down there, but if you can control the woods’ drying then it may still work okay. Best of luck.
KenBry
#2 posted 370 days ago
Yea, I was looking at using locally found woods and thought that drying out the lumber to fast in this heat might not work out to well.
View Gene Howe's profile
Gene Howe
3197 posts in 1599 days
#3 posted 370 days ago
Ken,
I’m in Snowflake and have brought back several hundred green BF of various species from TN, AR, GA, IL.
After about 3-4 months, everything is dry enough to use.
My mesquite takes less time but I’m not sure how long it laid in the log before I got it and milled it.
One caveat, most of mine is under roof and what isn’t is tarped. The pieces exposed seem to check readily.
KenBry
#4 posted 370 days ago
Yea, I was thinking about Tarping and end painting to keep things from going to crap. But for the moment it’s more a thought about doing this than practice.
View zombeerose's profile
zombeerose
63 posts in 2326 days
#5 posted 370 days ago
I live in Peoria, AZ and am in the middle of drying some rough cut pieces of mesquite/ash/eucalyptus in my garage. I cut them extra thick (1.5-2”) and heavily coated the end grain with latex paint. Make sure you stack them evenly with separators (~ every foot) made out of a wood that won’t discolor (oak has tannins that can stain). Considering the intense dry heat here in AZ, I would be less optimistic about drying outside, but if you do, I would opt for a shaded area then cover with plywood and weight it down. Make sure you elevate the boards off the ground/concrete. Ensure adequate airflow around all surfaces. Oh ya… and be patient … figure a year for every inch of thickness. Good luck :)
-- Maximize - Your Time, Your Experiencies, Your Life, Yourself!
View WDHLT15's profile
WDHLT15
687 posts in 647 days
#6 posted 370 days ago
No way that it will take one year for 1” wood to dry in AZ. Walnut and cherry dry to 12 – 14% here in GA in about 4 – 5 months, and even red oak air dries in 6 – 8 months. The humidity in AZ is much lower on average, so fast drying will occur. The moisture meter does not lie.
-- Wood-Mizer LT15
Gene Howe
#7 posted 370 days ago
Yep, no need to wait a year. Like I said earlier, 4 summer mo. for green stuff from back east. Mesquite, maybe a little less.
KenBry
#8 posted 370 days ago
I was thinking AZ in the summer = kiln dried, LOL
