linseed oil an bees wax
Forum topic by kizerpea posted 366 days ago 1455 views 2 times favorited 9 replies Add to Favorites Watch
View kizerpea's profile
kizerpea
586 posts in 534 days
366 days ago
whats the formula to mix linseed oil an bees wax
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
9 replies so far
View TheDane's profile
TheDane
2672 posts in 1829 days
#1 posted 366 days ago
kizerpea—- Not sure if this is what you are looking for … I have used a turpentine / bee’s wax / boiled linseed oil concoction.
It is an inexpensive ‘finish’ that is easy to apply and should be easy to maintain.
The recipe: 16 oz Gum Turpentine 2 oz shaved/grated Bee’s Wax (dissolve Bee’s Wax completely in turpentine) 16 oz Boiled Linseed Oil.
Apply liberally, let sit for two hours, then wipe off excess Let ‘cure’ for a few days, then buff.
—Gerry
kizerpea
#2 posted 366 days ago
gona put it on my handles…pitch fork,shovel,rake.hoe….............
View ssnvet's profile
ssnvet
1527 posts in 495 days
#3 posted 366 days ago
This combination (though I’m not sure of the ratios) is commonly used by Timber framers.
It’s rellatively inexpensive, easy to apply and easy to repair after the frame is raised.
Just make sure you soak your rags afterwards and dispose of them properly.
-- Matt, Pine is fine, but Oak's no joke!
View Fuzzy's profile
Fuzzy
249 posts in 2154 days
#4 posted 366 days ago
That is the ONE application for Linseed Oil with which I can agree … but, there is little need for the wax … just slather on the Linseed Oil, wait a while, wipe off what doesn’t soak in.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
View Bertha's profile
Bertha
13111 posts in 859 days
#5 posted 366 days ago
I also use beeswax and turpentine. I shave the beeswax finely then just slowly add turpentine until they’re suspended. I’ll put it on the windowsill for a few days. If I have to thin it, I just add more turpentine. I tend to like mine pretty thick. I’m not sure there’s an actual “recipe” that I’m aware of. Good luck.
View Everett1's profile
Everett1
202 posts in 700 days
#6 posted 366 days ago
I do the maloof mix; tung/BLO/Bees wax
I heatup the tung and blo in a crock pot, and mix in the wax
-- Ev in Framingham, MA
Fuzzy
#7 posted 365 days ago
You mix up a Moloof type finish for shovel/axe/rake handles ???
View Dusty56's profile
Dusty56
10505 posts in 1854 days
#8 posted 365 days ago
I also just use the Linseed Oil by itself on my handles…don’t forget the wheel barrow handles (if wood) : )
-- When did quiet and quite become the same word ? I'm guessing about the same time as your and you're did.
kizerpea
#9 posted 365 days ago
thanks for all the info…..............
