Exterior Wood that Bends
Forum topic by Brohymn62 posted 398 days ago 408 views 0 times favorited 1 reply Add to Favorites Watch
View Brohymn62's profile
Brohymn62
119 posts in 453 days
398 days ago
I’m currently involved with a project which original was suppose to use a composite material (Trex Deck) to wrap along a tall contoured wall on the exterior of a staircase. The owner has now expressed interest in using a natural wood… he’s suggested Ipe / Teak / Redwood… I know that Ipe and Teak would be a nightmare to try to bend around those curves… unless we made relief cuts?
Anyone ever work with Ipe or Teak in this kind of application? Would I be better off suggesting redwood or cedar for ease of use? Thanks ahead of time for your input!
-- Chris G. ; Los Angeles, CA
1 reply so far
View Mark Shymanski's profile
Mark Shymanski
3958 posts in 1910 days
#1 posted 396 days ago
Do you think thin teak strips < 3 cm would flex enough to make those large radius curves?
-- "Checking for square? what madness is this! The cabinet is square because I will it to be so!" Jeremy Greiner LJ Topic#20953 2011 Feb 2
