Bandsaw question
Forum topic by Iggles88 posted 374 days ago 753 views 0 times favorited 7 replies Add to Favorites Watch
View Iggles88's profile
Iggles88
203 posts in 534 days
374 days ago
Quick question. Is the fact that a blade runs true on the crown of a bandsaw mean that the wheels are definitely coplanar to eachother?
7 replies so far
View BilltheDiver's profile
BilltheDiver
170 posts in 1058 days
#1 posted 374 days ago
NO. It means your tracking adjustment is properly set.
-- "Measure twice, cut once, count fingers"
View killerb's profile
killerb
147 posts in 571 days
#2 posted 373 days ago
No. Coplanar is not a big thing. Crowning your wheels makes all the difference. bob
-- Bob www.bobkloes.com
Iggles88
#3 posted 373 days ago
Im not saying I don’t believe you because I’m sure you know much more then me but everything I’ve ever watched or read about bandsaws says that the wheels must be Coplanar or the tool will not run correctly. Im questioning that because if my blade tracks true and the wheels aren’t Coplanar then it must not be true
View Loren's profile
4901 posts in 1821 days
#4 posted 373 days ago
There are different methods of band saw setup. Co-planar is
one of them.
Crowning the tires causes the blade to run on the crown and
this can be a good thing with narrower blades. With wider
blades I prefer a flat wheel.
It may be helpful to set one leg of a square on the table
in from of the blade and see how square the relationship is.
In many cuts this isn’t relevant but in cutting corbels, for
example, it can be.
View flatboarder's profile
flatboarder
99 posts in 1029 days
#5 posted 373 days ago
Hey Loren, do you mind if I asked you a question ? I hope not . I just recently bought a new BS and Ive the blades wobble a little .I think there is too much taper on the front of the tires.could that cause the wobble.
-- Ive cut this board three times and its still too short?
View IrreverentJack's profile
IrreverentJack
665 posts in 1016 days
#6 posted 373 days ago
Matthias Wandel explains crowned pulleys on his site . I found some of his other bandsaw posts helpful too. -Jack
#7 posted 373 days ago
A little blade oscillation is common and it may not affect
cuts much as long as the upper guide is set close to the
work. Band saws don’t cut the same style of surfaces
circular saw do, so you’ll have to forgive the band for
wandering a bit even when the setup is meticulous,
because that is its nature.
Dunno about the degree of crown causing a wobble, but
I would check the tires to make sure they run true. You
can true rubber tires with a lathe chisel. On the lower
wheel it is easy do – just rig up a tool rest and turn the
saw on. Remove the blade first.
On the upper wheel have an assistant turn the wheel
using a rubber sanding drum chucked into a handheld
drill.
