Adjusting Timberwolf Blade on Grizzly GO555 14" Bandsaw
Forum topic by Lee Barker posted 05-16-2012 05:06 PM 1554 views 0 times favorited 2 replies Add to Favorites Watch
View Lee Barker's profile
Lee Barker
2170 posts in 2720 days
05-16-2012 05:06 PM
[First, if you’re reading this it’s likely you have a 14” or bigger bandsaw. Try the George B. System next time you change a blade: Take the table off! Take out the plug, the blade insert, unscrew the two knobs and lift it off. It makes adjusting everything so easy and much more accurate than the old fashioned way]
So I put on the 1/4×4 band and did the flutter adjustment per the instructions. I am cutting a 2” thick sandwich of mostly alder, 1/4 cherry. Slow rate of feed, not tight corners, cutting beautifully. After a few inches of cutting, the blade started fluttering on the left side, in the u-channel. I gave the tension another half turn and it went away, mostly.
Have you had any experience like this? Is there something else I need to look at? Did I miss something obvious?
Kindly,
2 replies so far
View toolie's profile
toolie
2099 posts in 2498 days
#1 posted 05-16-2012 09:26 PM
i resoleved my bandsaw problems by shelving every POS timberwolf blade i had (which was all 4 of the new blades i got when i got the saw). switched to lennox blades from iturra and it was like i got a new, much better, band saw. that flutter stuff is just a lot of hoaky and t-wolf welds are inaccurate. hope this helps.
Lee Barker
#2 posted 05-16-2012 10:32 PM
I can always find room for skepticism! Thanks for the insight, Toolie.
Kindly,
