Painting a plastic surface with latex paint
Forum topic by b2rtch posted 05-16-2012 12:41 PM 8078 views 0 times favorited 6 replies Add to Favorites Watch
View b2rtch's profile
b2rtch
4868 posts in 3289 days
05-16-2012 12:41 PM
Topic tags/keywords: tablesaw
Following my question on http://lumberjocks.com/topics/37986, if I get paint mixed at the big box store, most likely it will be latex paint.
Can i use this paint to spray paint a plastic surface?
I already primed this surface both with a “plastic” and ‘metal” primer.
Will it adhere or will it just peel after a while?
Thanks
-- Bert
View crank49's profile
crank49
4032 posts in 3212 days
#1 posted 05-16-2012 02:39 PM
Go to a decorating center, or paint store and have them mix you some enamel.
Nearly everyone has the computerized color matching capability these days.
View teejk's profile
teejk
1215 posts in 2925 days
#2 posted 05-16-2012 04:39 PM
seems to me that if it peels, it will be the primer’s fault, not the top coat.
View Loren's profile
10477 posts in 3889 days
#3 posted 05-16-2012 04:44 PM
Paint doesn’t adhere especially well to plastic in general. It
will stick, but it will scratch off easier than it does with metal
or wood.
View Doss's profile
Doss
779 posts in 2505 days
#4 posted 05-16-2012 07:31 PM
Like Loren said, paint doesn’t really enjoy sticking to plastic surfaces. Since it seems like what you’re painting isn’t going to be flexing much or be exposed to high heat or outdoor conditions (am I right?), then you could use what you are wanting to use.
Prep is going to be key here though (as with any paint job). I’d scuff the plastic first. Treat it with plastic adhesion promoter (like Bulldog). Then hit it with a coat of primer made for plastics. Then paint. Make sure the surface is completely clear of waxes/greases by using a prep cleaner (there are several at the different autoparts stores).
A lot of paint jobs fail either due to poor preparation or using the wrong product in the wrong environment.
-- "Well, at least we can still use it as firewood... maybe." - Doss
View gfadvm's profile
gfadvm
14940 posts in 2931 days
#5 posted 05-17-2012 02:04 AM
Rustoleum makes a rattle can labeled for use on plastic. I have used it on PVC pipe with no primer and no prep and been happy with it.
b2rtch
#6 posted 05-17-2012 09:16 AM
Thank you for all the replies.
I already cleaned and primed the surface with the Rustoleum plastic primer.
I shall have some paint mixed tonight and I shall paint the covers tonight, God willing.
-- Bert
