Porter Cable Low Profile Sander - dud?
Forum topic by rut posted 05-16-2012 11:56 AM 2543 views 0 times favorited 17 replies Add to Favorites Watch
View rut's profile
rut
65 posts in 2621 days
05-16-2012 11:56 AM
I decided to take a chance on this sander. Got it yesterday, slapped a new 120 grit sanding pad on it and gave it a try on some hard maple. Not sure if I’m doing something wrong or I got a dud but the thing only seems to work on a flat surface. I tried using it on the edge of the 3/4” piece and it wouldn’t event rotate. Even on the flat surface it seems to rotate slowly (and I have the speed control maxed).
I have an older Porter Cable sander and it goes fine on the edge and definitely faster than this newer one.
Has anyone else had this experience?
Rut
17 replies so far
View Bertha's profile
Bertha
13551 posts in 2932 days
#1 posted 05-16-2012 12:07 PM
Is this a random orbital sander or a pad sander?
View rut's profile
rut
#2 posted 05-16-2012 12:15 PM
It is the random orbital sander
View Bill White's profile
Bill White
5149 posts in 4200 days
#3 posted 05-16-2012 02:40 PM
HMMMMM? New and improved! BUT WAIT, we’ll send you a second sander. Just pay additional shipping and handling.
Now I feel better.
Bill
-- bill@magraphics.us
View syenefarmer's profile
syenefarmer
519 posts in 3320 days
#4 posted 05-16-2012 02:43 PM
I think you got a dud. I have the DeWalt identical twin to your Porter Cable and don’t have the issues you have.
Bertha
#5 posted 05-16-2012 02:45 PM
^I think you got a dud too. One of these powertool guys might have an idea for swapping brushes, bearings, whatever those little guys have. For what it’s worth, I have cheap sanders and expensive sanders. I’ve had good luck with DeWalt on the lower end of price.
View teejk's profile
teejk
1215 posts in 2924 days
#6 posted 05-16-2012 04:25 PM
I think the problem is how you are gripping it…I’ve owned several PC ROS machines and found that they don’t spin with even minimal downward pressure. I don’t have the low profile model but on the normal ones I grip it below the top (like holding a beer can) solely to guide it…let the machine do the work.
Give it try. If I’m correct, I’ll say you’ll be happy with it.
View AJLastra's profile
AJLastra
87 posts in 2468 days
#7 posted 05-16-2012 05:33 PM
Likely a dud. I have this sander and it works well. A thought though: I would avoid using a ROS on edge grain. Too risky to round over where you dont want a round over. This is where a palm sander comes in handy.
View SirFatty's profile
SirFatty
545 posts in 2451 days
#8 posted 05-16-2012 05:41 PM
Are you talking about the RO palm sander? I recently picked one up (after rebate, $35). I noticed that very same phenomenon. I fired up my older B&D Quantum and it works as expected.
I guess we both have duds?
-- Visit my blog at dave.spalla.com
View rut's profile
rut
#9 posted 05-16-2012 05:44 PM
“I think the problem is how you are gripping it”
I have a regular Porter Cable ROS (regular profile) and you have to press down pretty firmly to make it stop. On this new one with a speed control, anything less than full speed results in no turning of the pad under its own weight.
Guess I’ll send it back. Not sure if I want to risk another one or just stick with my old one. I liked the idea of the low profile for tight spaces.
teejk
#10 posted 05-16-2012 06:31 PM
rut…if that’s the case, probably a dud although I would try one more thing…lift it and turn it on to see if it spins.
PC was ruined IMHO when they were bought by BD/Dewalt. My guess is that PC quality tools were killed so they could shift the brand to “yellow”.
View rut's profile
rut
#11 posted 05-16-2012 06:33 PM
It does spin when lifted but nowhere near 12000 rpms (the reported top speed).
View jaidee's profile
jaidee
51 posts in 3018 days
#12 posted 05-16-2012 07:33 PM
I love my Milwaukee ROS. Got it when I returned the PC I bought previously. And it really works great hooked up to my shop vac for an almost dustless experience. I use a light touch with the ROS as it is too easy to “lean it over on edge” a bit if you press down, causing swirls ….. or as I call them, “more sanding”!
-- I used to be all thumbs......'til I got a tablesaw!
teejk
#13 posted 05-16-2012 07:59 PM
model number 390 or 394 rut? (just so I know to avoid it!) I run the cheap “single speed” palm model PC’s here and love them. the only variable speed model I own is that thing that looks like a car buffer and I only use it because it is PSA paper and makes quick work when needed.
Bertha
#14 posted 05-16-2012 07:59 PM
^I didn’t even know Milwaukee made a ROS! Shows how much I know. I’m going to check them out. Thanks!
teejk
#15 posted 05-16-2012 08:08 PM
jaidee I was a Milwaukee fan for years but then that German company came in and ruined that brand in favor of their own (seems to be a pattern on power tools huh?). I understand Milwaukee is now back with quality tools but many people “burned” during their bad time will still be leery of buying them again. And when you say “swirls” with a ROS…hmmm…that is the purpose of ROS and you shouldn’t have any if you step-up the grit on the sanding medium (rough stuff I might start with 50, then go to 120 and finish with 220).
