DELTA UNISAW PAINT MATCHING
Forum topic by b2rtch posted 05-16-2012 10:10 AM 12754 views 1 time favorited 13 replies Add to Favorites Watch
View b2rtch's profile
b2rtch
4868 posts in 3284 days
05-16-2012 10:10 AM
Topic tags/keywords: tablesaw question
As some of you know, I am working on a 1987 Delta Unisaw.
I bought a plastic cover for the motor and now I want to paint it to match the color of the saw itself.
I primed it last night, with a “plastic” primer then a grey primer.
I now try to find a can of paint the would match the color and that I could afford. Of course I went to my local big boxes and auto part stores.
I could not find anything.
I looked on line this morning and I found that “Sherwin-Williams High Seas Gray #650094014 ” is a perfect match.
The only problem is that this paint does not seem to be available any longer.
I also found out the Delta sales three different shades of grey (you are lucky if you know which one has been used for your saw) and none is a prefect match.
So if you have been in this situation before how did you resolve it?
Thanks
-- Bert
13 replies so far
View David Craig's profile
David Craig
2137 posts in 3344 days
#1 posted 05-16-2012 10:22 AM
Many paint supply stores (including big box stores like Home Depot) use scanners to scan in a color and the computer will mix in the proper quantities of red, yellow, and blue to acheive the color. Take a picture with a camera and bring the print in for scanning. If the pic is clear, they should be able to match it exact.
View dbol's profile
dbol
136 posts in 3234 days
#2 posted 05-16-2012 10:41 AM
I seriously doubt the paint will be an exact match, but I may be wrong.
If you goto OWWM.org. I think they will know what paint is suitable for your saw.
b2rtch
#3 posted 05-16-2012 11:36 AM
David, I have been thinking about doing that, in fact bringing the bottom cabinet door, but I need only one spray can of the paint,not a full gallon. If I find nothing else, thjis si waht I shall end up doing. Sherman Williams used to mixed the paint and to put ti in spray cans, I am not sure of they still do it. I also remember that it used to be quite e expensive. May be I should check that.
dbol, I shall check this website, thanks.
-- Bert
b2rtch
#4 posted 05-16-2012 11:54 AM
I am going to go to Lowes and have them match the color and then I shall spray my covers. Certainly this will be faster and cheaper.
I am not sure how well this paint will stick to plastic.
My covers are made of plastic.
I already primed them with “plastic” and then “metal” primers but still I have a doubt that the paint will stick very good.
Any better idea?
Bert
-- Bert
b2rtch
#5 posted 05-16-2012 12:00 PM
May be I got lucky, searching Sherwin Williams website I found this:
http://www.sherwin-williams.com/painting-contractors/products/catalog/controls-rustspray-enamel/
the color ‘650094014 C22470000 High Seas” seems to be very close.
I read on a different forum that this is color is not longer available.
I shall call sherwin-williams later on.
-- Bert
View Scot's profile
Scot
344 posts in 3632 days
#6 posted 05-16-2012 12:57 PM
I thought you didn’t like that gray color.LOL
Latex enamel will work just fine. I would not use any solvent based paint until I was sure it would not damage the plastic. The enamel will stay flexible enough to not flake or crack on the plastic cover.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
b2rtch
#7 posted 05-16-2012 01:13 PM
Scot, I guess I get used to the color, really it is not that bad, it is not the ugly dark grey, mine a a green blueish/sheen in it.
Thanks for the answer.
-- Bert
View MedicKen's profile
MedicKen
1615 posts in 3698 days
#8 posted 05-16-2012 02:49 PM
http://wiki.vintagemachinery.org/PaintColorsDelta.ashx
b2rtch
#9 posted 05-16-2012 03:52 PM
MedicKen, thank you for the link
-- Bert
View JK0702's profile
JK0702
138 posts in 2367 days
#10 posted 07-25-2012 08:52 PM
b2rtch, where did you get your motor cover? I’m having trouble finding one available for my 34-802 Unisaw. BTW, does anyone know of a link I can access to to find out what year my saw is by using the serial #?
-- John - Huntington Beach, CA --- Growth occurs when we get out of our comfort zone.
MrUnix
7106 posts in 2435 days
#11 posted 07-25-2012 09:14 PM
The SW “High Seas” is a good match.. I used it when restoring my band saw (1950 model 28-207) and it was a dead on match to what was there from the factory. Last time I was at my local SW store they still had it on the shelf and I haven’t heard anything about it being discontinued. Bert’s link above is to the correct stuff (“controls rust enamel”).
Edit: Serial number dating page can be found here:
http://wiki.vintagemachinery.org/DeltaSerialNumbers.ashx
b2rtch
#12 posted 07-25-2012 09:20 PM
I got some paint mixed at my local Lowes, the match is perfect.
I used latex paint for the plastic covers, it went on very well.
-- Bert
View deltafool67's profile
deltafool67
1 post in 1077 days
#13 posted 02-06-2016 04:06 AM
Delta used a variation of blue gray shades through much of its history. in the 1980s up until around 2001 the color they used was the “bluest” of all previous ones. Someone said that Sherwin Williams High Seas Gray is a perfect match. Well its not but damn close. High Seas has been discontinued by SW anyway. After much trial and error I want to share the following formula with those who are looking for this color.
Get Sherwin Williams Deep Base Oil enamel(6403-59691)Oil base gloss and add the following tint for a quart can
w1-white 15
b1-black 18
g2-new green 5
n1-raw umber 8
This is an exact match to the blue gray color Delta used up until 2001
