Scribe to fit conundrum
Forum topic by bluekingfisher posted 05-16-2012 08:29 AM 896 views 0 times favorited 6 replies Add to Favorites Watch
View bluekingfisher's profile
bluekingfisher
1247 posts in 2881 days
05-16-2012 08:29 AM
Morning fellahs – As part of the kitchen refit I have built a breakfast bar and intend to use a single large wood veneer panel matching the cabinets to cover the back of the kitchen base units.
The units protrude 90 degrees from the wall and measure 72” long. I have fitted the wooden worktops and then realised I will have to scribe the panel to fit between the underside of the work top and floor. The measurements of which vary between 34 – 34 1/2” (not in a continuous slope) so will need to be scribed.
I am confident on how to scribe the lenght against the wall but how do I scribe accurately between the underside of the work top and floor?. Obviously I don’t want to remove the work top as it is connected to the other worktops.
I suppose I could just cut it to the highest point dimension and use a lenght of bead to cover the gap but this doesn’t seem the way forward for a woodworker??
Any advice would be greatly appreciated.
David
-- No one plans to fail, they just, just fail to plan
View Bobmedic's profile
Bobmedic
376 posts in 2703 days
#1 posted 05-16-2012 08:50 AM
Use a shorter board to scribe then cut it out and transfer the pattern to the bottom of your panel.
bluekingfisher
#2 posted 05-16-2012 09:04 AM
Thanks Robert, just done a bit of research and that’s was the way to go about it.
Thanks
Bobmedic
#3 posted 05-16-2012 09:41 AM
No problem. I have had to do this on many built ins that I have done. It is labor intensive but works well. Good luck and best wishes.
bluekingfisher
#4 posted 05-16-2012 09:45 AM
Thanks Robert, I think the time spent on making a nice tight fit will be time worth spent. Nothing worse than looking at a job for years to come, wishing you had spent an hour or two extra at the time doing it right first time.
David
View Belg1960's profile
Belg1960
1058 posts in 2966 days
#5 posted 05-16-2012 09:46 AM
David, if you have a large cardboard box like from a fridge you could use that instead of wasting wood.
-- ***Pat*** Rookie woodworker looking for an education!!!
bluekingfisher
#6 posted 05-16-2012 09:49 AM
Hi Pat – My thoughts mirror yours, rather than use expensive boards, I have dozens of 6’ x 1’ lenghts of 1/8” hardboard. That should do the job just dandy.
I trust you are well?
David
