new work bench
Forum topic by MarkN posted 155 days ago 147 views 0 times favorited 1 reply Add to Favorites
View MarkN's profile
MarkN
28 posts in 256 days
155 days ago
hi all, it has been a long time since i have been here, that thing we call work has occupied all my time lately.
i decided that i needed to build a new bench because the one i have been using has become to old and rickety but because of the rising cost of living i decided to see if i could make it out of all the scrap wood i had laying around. i believe i have suceeded but have run into a minor problem. bench dog holes.\
What is the easyest way to bore them. my hand drill just doesnt have the power to do it and i don’t have many opptions to work with. any sujestions would help.
i will post pictures when i am through with it ( i hope tomorrow)
-- Mark from Deer Park, Texas
View Doug S.'s profile
Doug S.
217 posts in 245 days
155 days ago
I followed the lead of a poster on another WW forum with a jig to get the holes started straight as well as to set the spacing from hole to hole. I used a corded drill and a 3/4” brad point bit from Lee Valley which is pretty long. His jig was just a thick block of wood with a hole drilled thru then mounted to scrap ply or MDF with attached fence to set the spacing from the edge. I did mine a bit differently with 2 blocks mounted on MDF the full bench width and 2 more holes thru the MDF with the same hole-to-hole spacing and offset from the drilling block holes the distance between the rows that I wanted. Then I just kept inserting dowels thru the extra holes into the ones I just drilled and kept moving the jig down the bench. If you go that route, setup of the jig hole spacing and offsets are critical. I had to pitch the first one when 3-4 test rows on scrap ply showed me I was starting to steer off from parallel to the edge. Once the holes are drilled as deep as you can go, the remaining depth can be done without the drilling guide blocks and jig.
-- Use the fence Luke
Bookmark And Share This Page
