| Forum topic by BigMig | posted 371 days ago | 860 views | 0 times favorited | 11 replies | ![]() |
371 days ago |
Topic tags/keywords: dovetail trim tip I’m interested in options for trimming the ever-so-slightly-proud dovetails in a glued up box. Router with bearing…chisels…others? And lessons learned from your attempts that didn’t go perfectly? Thanks, -- Mike from Lansdowne, PA |
11 replies so far
#1 posted 371 days ago |
depends on how proud they sit. Table saw, band saw, belt sander, ROS, block plane, firmer chisel, old block of wood with a piece of sand paper glued to it, router, router plane….. the list goes on and on. My favorite way is to use a roundtuit. -- Improvise.... Adapt...... Overcome! |
#2 posted 371 days ago |
Dallas, that was great! Roundtuit… I might have to make me one of those :-D -- Mos - Twin Cities, MN -- Stanley #45 Evangelist - www.youtube.com/MosquitoMods |
#3 posted 371 days ago |
Not a roundtuit. It is a blockplanetuit. I have one. You can buy mine for $5,060.37 shipped. -- bill@magraphics.us |
#4 posted 370 days ago |
Mike, I like using a block plane. Sander works ok too. Router may give you some tear out. -- Tim-- http://www.tmuli.com |
#5 posted 370 days ago |
I have had the best results with a #4 stanley.I have had issues when using chisels,probably lack of control on my part or in a hurry.A super sharp chisel can dig if your not careful. -- They just don't get my chub on.-Bertha on modern handplanes |
#6 posted 370 days ago |
A sharp chisel with a sideways slicing cut or a sharp plane. Sanders are likely to round over a edge and a router would just be asking for trouble |
#7 posted 370 days ago |
i like to use the ball peen hammer trick to close any gaps, then trim flush with low angle block plane. |
#8 posted 370 days ago |
Bent, never heard of the ball peen hammer trick for wood dovetails. Can you elaborate? Sounds interesting. -- Mike |
#9 posted 370 days ago |
Mine are just alittle proud so i sand. I did try a scraper but got tear out. |
#10 posted 370 days ago |
paratrooper34 – you hit the endgrain of the pins close to the gaps. the rounded hammer head causes the wood to compress and spread out a little bit, thus filling in the gap. it works if the pins are proud and you trim them up afterwards, if they’re already flush, you’ll create a divot. |
#11 posted 370 days ago |
I usually leave the long grain proud and trim it flush with |
| Forum | Topics |
Woodworking Skill Share
8791 |
Woodturning
221 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
79 |
Finishing
1530 |
3547 |
15769 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6157 |
