Why do I need a dado nut on my Unisaw?
Forum topic by b2rtch posted 05-15-2012 04:13 PM 1728 views 0 times favorited 7 replies Add to Favorites Watch
View b2rtch's profile
b2rtch
4868 posts in 3290 days
05-15-2012 04:13 PM
Topic tags/keywords: tablesaw question
I see many advertisements for dado nuts for Unisaw table saws.
I never had to use one before on the other saws I owned
Thanks.
Bert
-- Bert
7 replies so far
View Loren's profile
10477 posts in 3889 days
#1 posted 05-15-2012 04:28 PM
Probably so the flange doesn’t interfere in deeper cuts
made with the dado set, cutting tenons vertically for
example.
View MrsN's profile
MrsN
987 posts in 3767 days
#2 posted 05-15-2012 05:36 PM
I think it is something with how much of the regular flange is threaded. I don’t think you can get the flange tight on a stacked dado.
I tried to use the dado nut with a single blade, and it wouldn’t thread on all the way.
b2rtch
#3 posted 05-15-2012 06:26 PM
I just called Delta with my question.
The answer I received is : this is a stupid engineer idea, you do not need it.
LoL
-- Bert
View syenefarmer's profile
syenefarmer
520 posts in 3322 days
#4 posted 05-15-2012 06:48 PM
If those were the exact words that Customer Service Rep said then I think I might ask for a second opinion. Just saying….........
b2rtch
#5 posted 05-15-2012 07:10 PM
I called again and I got a similar answer from another technician ( he just did not talk about the engineer). I do not need a special nut for dado
-- Bert
5244 posts in 2735 days
#6 posted 05-15-2012 07:55 PM
I’ve never even heard of a “dado nut” for the Uni. I run a stacked dado all the time with just the nut, on the wider cuts there is no room for the flange washer….......maybe that’s why they want to pick your pockets.
View DrDirt's profile
DrDirt
4526 posts in 3984 days
#7 posted 05-15-2012 08:09 PM
I have a unisaw, and use the freud stacked dado with the dial plate – and have always just used the regular nut over the past 7 years I had it..
Never knew there was such a thing as a dado nut.
I have seen the picture of the 36-201 nuts.
It looks like they have these two options becasuse the NEW Standard nut is one piece with teh flange washer. My saw has a ~2 inch flange and just a hex nut.
The new design (standard) with this flange attached would not work on a Dado set, that has a recessed hole. (like my Freud)
Since I have the OLD standard hex nut – it works on all blades just fine.
