OK I built these two as part of an iterative process.
Forum topic by guitarBuilder posted 156 days ago 146 views 0 times favorited 7 replies Add to Favorites
View guitarBuilder's profile
guitarBuilder
15 posts in 159 days
156 days ago
Topic tags/keywords: maple alder modern
I built these two guitars as part of a learning process revolving around luthiery (sp?) . Anyway, assembly of a hot rodded strat guitar can be tricky business and a lot more precise than folks realize. I will post a couple more threads when I have time. There guitars were assembled and came pre finished. I am starting from scratch and will post that guitar in progress soon.
The red one – Wild maple top on alder, red dye, maple neck
The blue one – 5a quilt top on alder, blue dye, ebony fret board on figured Anigre neck
Hope you like them.
View Loren's profile
248 posts in 184 days
156 days ago
Excellent. Try to track down a small overarm router if you
are going to build guitars – it’s a huge timesaver whether
you are building electrics or acoustics.
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online businesses - http://COPYMATCH.COM
View steveosshop's profile
steveosshop
178 posts in 162 days
156 days ago
I like the blue one. What kit did you get that from? They both look great.
-- Steve-o
guitarBuilder
155 days ago
I did not use a kit. I bought the bodies from a place called warmoth. the necks are also warmoth. The rest of the parts came from my stash. I have enough parts to built 10 guitars.
guitarBuilder
155 days ago
Forgot, Based on what I hear the only good acoustic kits are from Stew Mac. I find that hard to believe as I think grizzley sells one and i think Martin sells one. I bet those acoustics are great. There are no really good electric kits.
Also, I still had to do fret work with the 2 necks i bought from warmoth. the amount of fret work was very small.
View John Gray's profile
John Gray
882 posts in 422 days
155 days ago
Beautiful wood and nice guitars.
155 days ago
Acoustic kits should be fine. Watch out for a lousy soundboard though.
You don’t want to go to the trouble of building a guitar
only to find out later you should have used a stiffer soundboard.
Pro builders buy 2-3 times the number of soundboards they need,
check them over, and send the duds back.
6716 posts in 388 days
155 days ago
Excellent job
Bookmark And Share This Page
