Help me with dimensioning lumber for first project
Forum topic by Texchappy posted 05-13-2012 10:38 PM 929 views 0 times favorited 5 replies Add to Favorites Watch
View Texchappy's profile
Texchappy
252 posts in 2217 days
05-13-2012 10:38 PM
Finally about to get started on my first project. I got the lumber – poplar. I’ve got the dimensions for what I want it to hold (a torque wrench). My question revolves around the ‘fudge room’ I leave. When I’m cutting out the boards for each part – should I leave any ‘extra’ and if so how much?
TIA,
Tony
-- Wood is not velveeta
5 replies so far
View Bill White's profile
Bill White
4929 posts in 3957 days
#1 posted 05-13-2012 10:42 PM
Is the wood dry, finish planed, or rough sawn? What kinda joinery are ya gonna use?
This info will help us answer.
Bill
-- bill@magraphics.us
Texchappy
#2 posted 05-13-2012 10:44 PM
The wood is dry and somewhat planed. I was thinking about jumping right in and doing dovetails.
View waho6o9's profile
waho6o9
8189 posts in 2574 days
#3 posted 05-13-2012 10:54 PM
One might want to practice on scrap first, and then practice some more.
Patience my friend.
Bill White
#4 posted 05-13-2012 10:56 PM
Well, are ya good a DTs? If new at the process, you might want to practice some before you dimension the lumber.
Plane as needed to final thicknesses, allow the wood to sit for a few days to allow for any “wiggle”, cut to final dimensions and DT away.
Bill
View oluf's profile
oluf
260 posts in 3036 days
#5 posted 05-13-2012 11:00 PM
For me it depends on the size of the piece that I am cutting my parts from. If I am not going to have a useful cut off than I will cut quite long or wide. If the stock is twisted or bent than I cut very close to the final size to reduce the waste from bringing the stock to square. If your equipment leaves snipe you will want to cut long if you can. I often rip twisted stock into thin strips, flatten one side and then edge glue them back togather again.to keep from having to lose so much thickness. Study the wood before you cut it.
-- Nils, So. Central MI. Wood is honest.Take the effort to understand what it has to tell you before you try to change it.
