What 8" dado set to get?
Forum topic by Cato posted 05-13-2012 01:22 PM 2503 views 3 times favorited 22 replies Add to Favorites Watch
View Cato's profile
Cato
701 posts in 3282 days
05-13-2012 01:22 PM
I am looking for an 8” dado stack for my TS and was wondering what you guys might recommend?
I bought an inexpensive CMT 12 tooth set at Lowe’s a week or so ago that was on clearance for $76, but when I got home and checked their website for reviews most said that their set had an oversized chipper that left a groove.
I think I will return it unused and look for a higher quality set.
As I don’t do a ton of work at this point requiring dadoes I would like to be more in the $100 range.
Any help would be appreciated.
Knotscott you out there?
22 replies so far
View Mike DeCarlo's profile
Mike DeCarlo
40 posts in 2728 days
#1 posted 05-13-2012 02:26 PM
I bought the Freud SD508 8” Dado Set about 12 years ago, it was pricey but well worth it!
-- http://decarlowoodworks.blogspot.com
View Nicky's profile
Nicky
695 posts in 4061 days
#2 posted 05-13-2012 02:35 PM
I’m very happy with the Delta 8”. Bought it through Amazon for about $100 with free shipping.
-- Nicky
View b2rtch's profile
b2rtch
4851 posts in 3018 days
#3 posted 05-13-2012 02:36 PM
Cato, I have the cheap HF and I am very satisfied with it. It cuts clean and flat bottom.
You could try it and return it if you do not like it.
I also have another more expensive set bought on Amazon, which in opinion is not working any better.
set
-- Bert
View knotscott's profile
knotscott
7985 posts in 3345 days
#4 posted 05-13-2012 02:44 PM
Hi Cato – At the high end, the Infinity Dadonator is the best set I’ve used to date….very impressive….I’ve literally struggled to tell the entry from the exit on several occasions. I’m sure other precision sets like the Forrest Dado King, Ridge Carbide Dado Master, or Freud SD508 are excellent too, but of the precision sets, only the Dadonator offers 6-tooth chippers. Number of teeth isn’t the only factor that influences cut quality, but I can’t help but think that 50% more teeth on the chippers of the Forrest, Ridge Carbide, or 508 would help them cut cleaner too. (Save $10 With Any Purchase Over $125 – Use Promo Code ”WINTER12” Today!)
For under $100, the Delta/DeWalt 7670 set gives a taste of the high end sets for half the cost….has a similar design to the Forrest. Nice carrying case, nice shim stock, well designed, well made, but is made in China.
View quartrsawn's profile
quartrsawn
146 posts in 3183 days
#5 posted 05-13-2012 02:46 PM
I’m happy with the Freud 8” Pro Dado,paid $90-ish few years ago (about $100 today), nice clean dados. There was another thread on dados couple moths ago.
-- Nat - West Sayville,L.I., NY
View jusfine's profile
jusfine
2422 posts in 2895 days
#6 posted 05-13-2012 02:55 PM
Freud here as well.
-- Randy "You are judged as much by the questions you ask as the answers you give..."
View tsdahc's profile
tsdahc
107 posts in 2321 days
#7 posted 05-13-2012 03:01 PM
I went with the oshlun, about $75 or so on amazon. I think it does a great job for the price. Its gotten good reviews on here as well. The box it comes in isnt a nice wood or plastic, its cardboard but I dont care. Its held up and if need be I can make a wood box for it. It makes a nice flat bottom and the ears are very hard to see on the outside of the cuts. Again for the money I think its a better set then the frued for about the same price. The delta/dewalt I havent used but its about $30-40 more and it doesnt do that much better from what Ive read. Good luck on finding a dado set.
View teejk's profile
teejk
1215 posts in 2654 days
#8 posted 05-13-2012 04:19 PM
I’ve been using a Delta set for several years and have no complaints. It came with an extra “under-sized” chipper to accommodate undersized plywood and several cardboard shims that allow for fine-tuning. I suppose that is standard in any brand now but I don’t know since I haven’t shopped for one recently. Very important to have though since most 3/4” ply is no longer 3/4”, 1/2” no longer 1/2”, etc.
10283 posts in 3617 days
#9 posted 05-13-2012 04:35 PM
You know you can get a router bit with a bearing that cleans
out and flattens dado bottoms. See you’ll have a hard time
pressing a board perfectly flat on your TS so the depth of
the dado will generally vary a bit anyway. Would you rather
have the edges of your dado be a bit deeper or the center?
If you say “neither” you may be chasing a costly ideal.
For truly flat-bottomed, consistently depthed dados
shops that do a lot of dados often turn to a panel router.
But in any case, the Forrest is probably in the top class
and Freud cutters and blades are always a good value in
my experience.
View MrRon's profile
MrRon
4722 posts in 3213 days
#10 posted 05-13-2012 05:45 PM
Do you really need an 8” dado? 6” dados work just as well and are cheaper. I don’t use dados often, so I have the HF set. It’s cheap and works for me.
View killerb's profile
killerb
150 posts in 2368 days
#11 posted 05-13-2012 06:31 PM
Another vote for the Infinity. I have had a few other ones over the years. This is heads and atils above those, including the forrest. bob
-- Bob www.bobkloes.com
View Sawkerf's profile
Sawkerf
1730 posts in 3038 days
#12 posted 05-13-2012 06:33 PM
I have the Systi-Matic set and got a set of magnetic shims for fine tuning the setup – although my last few projects have all used full 3/4” sheet goods. I really like the magnetic shims because they don’t try to drop slightly into the arbor threads during setup and foul things up.
I always wonder why people are so adamant about flat bottoms. One of my chippers is slightly off and I get a slight (~1/64”) groove in my dados. So what?? I use dados for carcass construction and then add faceframes. That tiny groove never sees the light of day, anyway. Even if it wasn’t hidden, it takes a very close inspection to see it.
teejk
#13 posted 05-13-2012 07:44 PM
sawkerf…magnetic shims??? the cardboard ones I got with my Delta set are about the thickness of a 12 pack beer box and the center hole is tight on the arbor (hint there for anybody wanting to make their own)...I use the same material for shimming door hinges when somebody has a problem…add as many or few as you need…
I’ve never seen a “groove” but from time to time I’ll see a “ridge” (at the location of the cardboard spacers which I could easily remove with a finger nail).
“Groove” in your range underestimates the power of today’s glues (not that you even need that excuse with 1/64” which nobody would notice with or without a face frame). Ridge is easily handled with a chisel (and I do that anyway…a pass takes all of 20 seconds or so).
View John 's profile
John
253 posts in 3371 days
#14 posted 05-13-2012 07:58 PM
I use an Amana for doing cabinetry and fine finish work and I have another set on my RAS that I bought used from a shop I used to work at when they closed up shop. I wish I could find the brand cause it’s been a real bruiser for over 18 years.
-- John
View NewEnglandsWoodWorks's profile
117 posts in 2571 days
#15 posted 05-13-2012 08:39 PM
Freud works well for me, a bit pricey but its nice.
-Brett
-- Brett
