Glue and Finish, Are They Compatible
Forum topic by dusty2 posted 370 days ago 626 views 0 times favorited 6 replies Add to Favorites Watch
View dusty2's profile
dusty2
281 posts in 1595 days
370 days ago
I have all the parts cut for a small project and because of its size I decided to pre-finish the parts. I was not careful and got a lot of the finish in the dados. I wiped the dados clean so I don’t have a fit problem but am I going to have a problem with the glue not adhering to the finished surfaces.
I used a Minwax polyurethane and stain and I use Titebond III.
I have a real bad feeling about this. Hopefully you will tell me I am wrong and it will work.
-- Making Sawdust Safely
View waho6o9's profile
waho6o9
2878 posts in 742 days
#1 posted 370 days ago
Hello epoxy
I too finish before glue up and like to tap off said dados. Things will turn out fine Dusty2.
dusty2
#2 posted 370 days ago
waho6o9: are you telling me that I should use epoxy or will the Titebond work?
waho6o9
#3 posted 370 days ago
I would suggest using epoxy as it will adhere better than Titebond.
Or, you can take scrap pieces of your project, finish as you did with your small project using
minwax polyurethane and stain and practice using Titebond and see if it holds up. Kinda
like a practice run using scrap.
Join some stained minwaxed scrap wood, glue, let set, and smack it with a hammer and see
what happens.
View Shopsmithtom's profile
Shopsmithtom
768 posts in 2360 days
#4 posted 370 days ago
I also would recommend epoxy in this case, or really whenever you pre-finish. That way, you won’t have to worry if you get finish stuff in the joint.
Another possibility if you don’t like 2 part glues, is to use a thick cyanoacrylate. (super glue) Not the thin stuff used for general gluing, but the thick stuff made for gluing wood. The tricky part about that, though, is to get used to the extremely quick setting time. If you can, it can be a really good solution. -SST
-- Accuracy is not in your power tool, it's in you
dusty2
#5 posted 369 days ago
Thanks for the responses. I got it done.
View dbray45's profile
dbray45
2018 posts in 942 days
#6 posted 369 days ago
Another thing – get the folks at Titebond a call, they are really good at telling you what to use for different applications.
-- David in Damascus, MD
