white lines
Forum topic by Jon1094 posted 373 days ago 574 views 0 times favorited 4 replies Add to Favorites Watch
View Jon1094's profile
Jon1094
28 posts in 373 days
373 days ago
First post here everyone…thank you for the help.
I just put the seventh and final coat of lacquer on a chessboard. I used wood filler, packed it into the grain and used a painters spatula to smear it in. I waited for it to dry and applied a coat of shellac. I applied seven coats of lacquer and am now noticing that there are little light colored strips appearing along the grain of the wood. The strips are about 1-2 mm long. I used maple and walnut and the strips are only appearing in the walnut. Any ideas?
View killerb's profile
killerb
147 posts in 566 days
#1 posted 373 days ago
Did you wipe the filler off? Sounds like you didn’t clean all the filler off before sealing. You will have to strip off the lacquer to clean off the filler. Sorry to be the bearer of bad news. It has happened to me before. Only takes once. Good luck. bob
-- Bob www.bobkloes.com
Jon1094
#2 posted 373 days ago
This is what I’ve got so far. I sanded the surface after I put the wood filler on and used a tack cloth afterwards. It only appeared after the fifth or so coat of lacquer.
View adaughhetee's profile
adaughhetee
80 posts in 851 days
#3 posted 372 days ago
It looks like your tack cloth didn’t get all the dust out and it got trapped under the next layer of lacquer. Are you sanding between coats? If so it could be lacquer sanding dust trapped in the low spots. I’ve had this issue sanding between coats on walnut before.I had to use something wet like mineral spirits or water with a rag to get it out of the low spots. Just a thought.
Jon1094
#4 posted 372 days ago
Maybe that’s it…I did knock down a few spots on the lacquer with paper between some of the coats. I don’t think I wiped it off but it didn’t look like anything was there. Well that wont happen again. Dang! Thanks for all the help.
