| Forum topic by Texchappy | posted 404 days ago | 1079 views | 0 times favorited | 9 replies | ![]() |
404 days ago |
When set up to function as a jack plane, how smooth a surface can a jack plane leave? What factors influence this? TIA, -- Wood is not velveeta |
9 replies so far
#1 posted 404 days ago |
It’s a matter of honing and tuning, but a jack plane The smooth plane dives into minor hollows left by You can smooth with a jack, but the smoother is |
#2 posted 404 days ago |
A jack plane set up as a jack plane or fore plane will have a cambered cutting edge and will leave a scalloped surface. While you want to avoid tear out with the jack/fore plane a smooth surface isn’t the goal. The goal is to use the plane’s length and cutting edge to rapidly and in a controlled manner remove high areas on the face or edge of a board. If you want to make sounds similar to fingernails on a black-board, just talk about setting up a jack plane as a scrub plane. A jack plane should be set up for roughing and there were no scrub planes in traditional Anglo/American woodworking. Scrub planes were a Continental phenomenon and don’t show up in British or American plane catalogs until they appeared as “Bismarks” in the late 19th Century or early 20th Century. |
#3 posted 404 days ago |
Pretty darn smooth, depending on how you have it set up. -- John, BC, Canada |
#4 posted 403 days ago |
The reason I ask is that I see that I see recommendations of getting a Jack fairly often and I don’t know when I could get a general smoother. The Anarchist Toolchest (which I just read, really like, and keep mentioning) puts a smoother under ‘nice to have’. Don’t really want to use sand paper and not sure I’m confident enough in sharpening etc to have a couple of blades to change out like he recommends. Hmm, what to do. -- Wood is not velveeta |
#5 posted 403 days ago |
Used just a jack on this beam Actually, I have two jacks, one with a cambered iron, the other has a straight edge. i roughed this down with the cambered one, then went over it with the square edged jack. I also hit it with a couple of the long bodied planes, just to level things out. Afterall, i had a top to do -- A Planer? I'M the planer, this is what I use |
#6 posted 403 days ago |
Good answers already, but just remember the ONLY difference between a smoother and a jack plane is the length. If your plane is set up and tuned well with a sharp blade and the blade set for a very slim cut, it can do very well. The reason everyone says get a Jack first is because it is long enough to flatten some stuff, and short enought to smooth some stuff. If you are using it for both, though, you may want to plan on honing the edge between roughing and smoothing, since the deep cuts will put more wear on the edge. -- I'm strictly hand-tool only...unless the power tool is faster and easier! |
#7 posted 403 days ago |
Texchappy…..... sharpening is very easy with all the jigs and sharpening machines on the market. Freehand sharpening is also very easy, but alot of people dont like the time it takes to learn. Please dont let sharpening be a factor when considering hand tools. Sharpening is a no brainer. |
#8 posted 403 days ago |
Jack of all trades, hence the name for the Jack plane. |
#9 posted 403 days ago |
I have SB #5 that I tuned up. I flattened the frog, sole, sides, etc. I installed a Hock blade and chip breaker. The blades corners were relieved a tad and no marks on the wood. It will cut fluff. The blade is too thick so I cannot take a serious cut with it. My next step is to open the mouth a little at a time to get a little thicker cut. It is my general go to plane and I love it. -- Jerry |
| Forum | Topics |
Woodworking Skill Share
8850 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1600 |
3595 |
15985 |
Hand Tools
2104 |
Jigs & Fixtures
501 |
Wood & Lumber
2911 |
813 |
Focus on the Workspace
926 |
778 |
Woodworking Trade & Swap
2778 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6136 |
