| Forum topic by Garyb6 | posted 62 days ago | 190 views | 0 times favorited | 9 replies | ![]() |
62 days ago |
62 days ago |
I use Titebond III. Seems to be workable for quite some time. Titebond II sets real fast. -- Bill - If I knew GRANDKIDS were so much fun I would have had them first. |
62 days ago |
titebond is what i use for all glue ups. haven’t had many really complicated glue ups though. i know David Marks uses plastic resin glue for complicated glue ups. |
62 days ago |
On projects such as multi-panel doors, I use 24 hour epoxy. Lots of open time, which makes the tedious job of gluing up a much more relaxing part of the project. Otherwise I use Titebond III. -- Phil in British Columbia |
62 days ago |
I use Titebond III, just be aware of how well it bonds and that it is a pain to clean up the squeeze out. Just finished assembling 10 drawer for my miter bench. -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
62 days ago |
TightbondIII, I know David Marks uses the 24hr epoxy. If you nood a lot of time the 24 hour epoxy seems the go. -- Grumpy - "Always look on the bright side of life"- Monty Python |
61 days ago |
White glue. White has a longer working time than I use white glue for joinery. Elmer’s is fine. For veneering or other applications where “creep” is I think white glue dries more brittle than yellow. Yellow I haven’t used 24 hour epoxy. When doing complex Pieces sometimes get heavy during assembly and need to -- Need help with marketing your business? Look in my profile. |
61 days ago |
Use hide glue. You can buy it from Rocklers or wherever. It has an extended setup time and cures to psi ranges above most glues. It is actually a TiteBond product, also. If you use hide glue, it does not run and drip like other glues. I started using it in the past, and now use it all the time. It stays where you put it. You may also want to look at gluing up sub assemblies to make your life easier. Unsolicited advice, but hide glue is the way to go for big time glue ups. As always, bbqKing -- bbqKing, Lawrenceville |
61 days ago |
Thanks everyone. I used Titebond III. It worked well. I may also try hide glue in the future. I have to order it though. No sources close by. -- Garyb6, Hampton, VA |
61 days ago |
I just used Titebond III for assembling my sewing machine table. It had the working time I needed to get the glue on all faces of the joinery, assemble all the parts, and knock everything into alignment with a dead blow hammer. -- Dust collectors suck. |
| Sponsor | Forum | Topics |
Woodworking Skill Share
1127 |
1508 |
103 |
295 |
95 |
Woodworking Trade & Swap
204 |
Coffee Lounge
818 |
LumberJocks.com Site Feedback
254 |
