| Forum topic by Don W | posted 373 days ago | 941 views | 0 times favorited | 18 replies | ![]() |
373 days ago |
I have 2 questions. 1. what is it.
-- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
18 replies so far
#1 posted 373 days ago |
It’s either and antique shopvac canister frame, or a boat anchor. -- Failure does not stop me, it makes me try harder..... because I'm crazy. |
#2 posted 373 days ago |
It looks like some kind of coupling. When the outside thread is tightened, the three jaws will grip onto round stock, so why don’t you stick a flag pole in that thing and concrete it into the ground? Hang on a minute. Is it a primitive bearing puller? -- Andy -- Old Chinese proverb say: If you think something can't be done, don't interrupt man who is doing it. |
#3 posted 373 days ago |
What about a stand for a Christ-mas tree? -- Bert |
#4 posted 373 days ago |
your correct Andy, (not bad for a DB guy), I’m thinking fire hose coupler or something like that. I didn’t want to chuck it (no pun intended) if some one had a use for it. I’d gladly trade it for a stanley #2. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#5 posted 373 days ago |
Good Question, What is it? Oooh I knew that. -- ~ Bob ~ Newton, N.H. |
#6 posted 373 days ago |
Tree holder for chain saw sculpting? ...Antique neck brace? ...Truth extractor?...Medieval house arrest ankle monitor? -- so much wood, so little time. Bradford. Wood-a-holics unanimous president |
#7 posted 373 days ago |
LARGE threader for pipe? Should be a “ratchet-like handle’ that attaches to the outside. Clamp the pipe to a bench top “vise’, and spin this threader onto the pipe. That ratchet should have a locking ring, to set the size of the pipe to the threader. -- A Planer? I'M the planer, this is what I use |
#8 posted 373 days ago |
i’ve used the pipe threaders that bandit571 is talking about. they look similar to this, but i don’t think that is what it is. i don’t see any cutting teeth on it. |
#9 posted 373 days ago |
Don’t let my wife see it, she’ll want to turn it into a planter and stick flowers in it. -- "It ain't what you don't know that gets you into trouble. It's what you know for sure that just ain't so." - Mark Twain |
#10 posted 373 days ago |
Don, I believe you have correctly identified it as a Fire Hose Coupler. They were used to put new couplings (ends) on fire hose. Each half of the fire hose (male coupling and female coupling) is a two-piece fitting with the double jacketed hose sandwiched in between. There were ridges running around the inner face of the outside half and around the outer face of the inside half of each fitting that, when coupled, prevented the hose from slipping out of the coupling. This appears to be the tool that would make all that happen. Cheers! -- Dave; Lansing, Kansas |
#11 posted 373 days ago |
You were close on the fire hose coupling, It’s actually a fire hose recoupler. It was used to press new ends on fire hoses. They were a royal pain to use. -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#12 posted 373 days ago |
naa all wrong Dennis |
#13 posted 373 days ago |
is it worth anything? I’d give to someone if they wanted it. -- There is nothing like the sound of a well tuned hand plane. - http://timetestedtools.wordpress.com (timetestedtools at hotmail dot c0m) |
#14 posted 373 days ago |
Might it be of use to your local volunteer fire department? -- "Hard work is not defined by the difficulty of the task as much as a person's desire to perform it.", DS251 |
#15 posted 46 days ago |
well, one antique shop listed it as a xmas tree holder. Mine was missing the removable legs.
| Forum | Topics |
Woodworking Skill Share
8785 |
Woodturning
219 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
77 |
Finishing
1523 |
3542 |
15757 |
Hand Tools
2031 |
Jigs & Fixtures
494 |
Wood & Lumber
2834 |
808 |
Focus on the Workspace
900 |
766 |
Woodworking Trade & Swap
2738 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6150 |
