Mounting a Bosch 1611 plunge router in a router table
Forum topic by b2rtch posted 373 days ago 1670 views 0 times favorited 12 replies Add to Favorites Watch
View b2rtch's profile
b2rtch
2953 posts in 1215 days
373 days ago
Topic tags/keywords: question router
As some of you know by other forums, I just bought a Bosh 1611 plunge router that I would like to mount in a table saw router extension that I also just bought.
This router develops 3 /14 HP which I believe would be “just fine” in a table.
I have two issues:
1-I have only a 1/4” collet for it and Bosh no longer sales the 1/2” collet (or any other part) for it. Where can I find a 1/2” collet? I looked on E-bay, no luck
2- How to mount a plunge router in a table (I know for a fix base) and then how to adjust the depth of cut?
Thank you for any help.
Bert
-- Bert
12 replies so far
b2rtch
#1 posted 373 days ago
After Bosh told me that this collet is no longer available I just found and bought one on Amazon, so question#1 is answered.
-- Bert
b2rtch
#2 posted 373 days ago
On “router forum” someone suggests to use a “Router Raizer” to solve my issue but no one seems to be sure that the “router raizer” would work with a 1611.
If checked on Rockler bu there is no information
Do know if it would or not?
Thanks
-- Bert
b2rtch
#3 posted 373 days ago
I just talk to “router raizer” and they told me that they could never get this router to work in their raizer, it would raise a little bit and just bind.
Did you say “out of luck”?
-- Bert
View KnickKnack's profile
KnickKnack
805 posts in 1733 days
#4 posted 373 days ago
You’re gonna (maybe) think this is silly, but I have my plunge Bosch router in a home grown table. Mounting was just with 3 long bolts with butterfly buts on the end.
As for raising it – I adjust the “depth of plunge” sider, and lever it up with a piece of wood – somewhat low-tech, but easy and it works pretty well.
-- "Do not speak – unless it improves on silence."
b2rtch
#5 posted 373 days ago
KnickKnack, I was just thinking that the 1611 bind because the router raizer try to pull it up on only one side/post.
Now if I was to install a jack under the router and in the center it should work just fine. I could use a small inexpensive ( read HF) hydraulic bottle jack or a small screw jack.
http://www.harborfreight.com/1-1-2-half-ton-scissor-jack-66907.html
or
http://www.harborfreight.com/4-ton-hydraulic-bottle-jack-66450.html
I believe that the mechanical jack would easier to adjust.
-- Bert
KnickKnack
#6 posted 373 days ago
Both those sound like good ideas, I knew someone had done something similar on here once, and I finally managed to find it.
b2rtch
#7 posted 373 days ago
Yes, I saw that after I posted the message.
-- Bert
View George_SA's profile
George_SA
171 posts in 380 days
#8 posted 372 days ago
I have a similar problem with a Bosch plunge router. I also have a spare scissor jack which I consider using as a router lift. I would like to see some pics of the solution you came up with.
Regards
-- Integrity is doing the right thing when no one is watching.
b2rtch
#9 posted 372 days ago
1 Tim. 1 v 15
Amen
I shall write later
-- Bert
View ssnvet's profile
ssnvet
1527 posts in 495 days
#10 posted 372 days ago
Some of these big honkin 3 HP routers had conversion kits that exchanged the smooth depth stop rod with a threaded rod with a star knob and nut on the top. This changed the router from a plunger to a dial a depth router.
I put PC’s conversion kit on my PC 3 HP plunger and have it mounted in my router table. Some have posted pics where they drilled a hole in the router base and extended the threaded rod through their router table plate for a built in top accessible lift mechanism.
-- Matt, Pine is fine, but Oak's no joke!
View MT_Stringer's profile
MT_Stringer
707 posts in 1397 days
#11 posted 372 days ago
b2rtch
#12 posted 372 days ago
ssnvet, yes I saw it and I had the same idea before I saw it, to is ma not copying it but we both are genius. My concern about this idea is that I shall have my router enclosed in a cabinet for dust collection purpose and that the drive on the jack goes up and down with the jack.
I have been thinking about using an hydraulic bottle jack but again the handle goes up and down.
Last nigh in my bed I was thinking that what I really need is one of this jack found on American cars which look like a bottle jack but which the handle on the bottom just turn, not going up and down.
I also was thinking that the Router Raizer does not work with this router only because get lifted/pulled up on only one plunger and then it get crooked and binds. If the bushings indie the plunger were made better or of a different materiel this probably could be remedied. I need t take it apart and to look at he bushings.
I am going to start a blog about my work on this saw.
Follow the blog
-- Bert
