Tail vise for Roubo work bench?
« back to Hand Tools forum
Forum topic by Brett posted 05-10-2012 08:39 PM 10863 views 0 times favorited 6 replies Add to Favorites Watch
View Brett's profile
Brett
660 posts in 2680 days
05-10-2012 08:39 PM
I’m (very) slowly building a Roubo workbench. For those of you you use hand tools on a workbench with a tail vise, what sort of tail vise have and what would you recommend?
-- More tools, fewer machines.
View Brandon's profile
Brandon
4152 posts in 2948 days
#1 posted 05-10-2012 08:57 PM
A lot of people put wagon vises in their benches. I used a front vise as my tail vise. It works great. I drilled a couple of dog holes in the chop, so that it can still hold material for face-planing. Here’s my bench:
Click for details
-- "hold fast to that which is good"
View BubbaIBA's profile
BubbaIBA
387 posts in 2373 days
#2 posted 05-10-2012 09:01 PM
Wagon vice by BenchCrafted was designed for use on Roubos. There are enough work holding options with the Roubo I even thought about not adding a tail vice….still not sure one is needed.
Brett
#3 posted 05-10-2012 09:36 PM
Brandon, I’m unsure how well a tail-vise with a dog hole mounted in the chop will work if I put my dog holes 2” or so from the front of the bench. Do you experience significant racking forces when you use your tail vise for face planing? I guess I could try to make a wagon vise, but that might be too much of a challenge for this beginning woodworker.
Brandon
#4 posted 05-10-2012 09:52 PM
A wagon vise is preferred if all you want to use it for is face planing. That said, I use the tail vise all the time—much more frequently than the leg vise because it can hold all sorts of things. I have two rows of dog holes, so wider pieces will engage both sets of holes and will not rack at all. When I only use one row of dog holes, it will rack a little, but it’s not really an issue because the bench dog is what holds the wood, if that makes sense. Racking is not an issue at all for me—perhaps I’ll take a picture when I’m at home to show you what I’m talking about.
I used the large front vise from Lee Valley and it was a breeze to install.
View jmos's profile
jmos
827 posts in 2366 days
#5 posted 05-10-2012 11:18 PM
I made a twin screw vise that spans the width of my bench from two metal screws. I’ve got rows of dog holes every 3” on either edge of the bench, and a row down the middle of the bench about 12” apart. Each is in line with a dog hole in the chop of the twin screw. It’s in my bench build blog. Works nicely. I primarily wanted it so I can clamp drawer sides for dovetailing. Could have gone with a Moxon vise, but I didn’t want something else to store.
I use my tail vise a lot, at least as much as the leg vise.
-- John
Brandon
#6 posted 05-10-2012 11:23 PM
I love that vise, John. There’s a good chance I may have went down that road had I thought about before building my bench.
