| Forum topic by Scot | posted 404 days ago | 583 views | 1 time favorited | 14 replies | ![]() |
404 days ago |
It seems that there are always someone asking about DC systems so I thought I would show how I’m installing mine. It is about 1/3 complete but works fantastic so far.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
14 replies so far
#1 posted 404 days ago |
#2 posted 404 days ago |
OK, this might be a dumb question, but why would you not turn the DC unit around so the inlet is facing the wall and then just 90 up from there? You’d eliminate 2 of the 90 degree elbows you’re using to get you from the inlet to the wall behind the DC. Not criticizing by any means. Just wondering. My DC is nowhere near as powerful as yours so I’m always looking at shortest run and fewest elbows. Maybe with yours, it’s got enough power that those 2 elbows are meaningless in the overall scheme of things :) |
#3 posted 404 days ago |
Very nice! A really clean install. I’m planning on doing the same to my shop this Fall. I have some questions if you don’t mind me asking: It looks like it’s all metal duct, what type did you use? What gauge? It looks like you used PVC for the drop to the table saw, but metal for the drops to the rest. What was your reasoning for that? Thanks! -- John |
#4 posted 404 days ago |
Charlie, the DC itself is just temporary. Eventually the motor and blower will be mounted directly on top of the cyclone separator. -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#5 posted 404 days ago |
Actually that’s not pvc, it’s black stove pipe. I used the stove pipe because it is much heavier gauge and the pipe to the table saw is much more exposed than the other down comers. However, pvc would have been much cheaper and just as durable, but the stove pipe was given to me. All the other ducting is 26 gauge, the y’s are a little lighter gauge, I get them at lowes and home depot. -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#6 posted 404 days ago |
Nice job scot, and thank you for sharing your shop photos with us LumberJack viewers. I just ordered and received the same DC as yours. I have not set mine up as of yet. However, I like to know how you like it so far?, is it loud?, (I mean noisy) and did you get a remote with it as well? Nice set up. |
#7 posted 404 days ago |
It is noisy, border line loud. A Powermatic it is not, but it moves a heck of a lot of air. I do like it and as I stated before I’m going to make a filter box and have four filter instead of two and no bags. this should muffle the blower noise some. I did this to a harbor freight DC for a friend and reduced the noise substantially. I’m using a shop fox remote that works ok. If and when it dies I will look into a better quality remote. -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#8 posted 404 days ago |
Scot, have you tried (intentionally or accidentally) running the DC with all the ducts closed? There’s been some question about 26ga being able to withstand full vacuum without collapsing. I’ve seen pictures where 30ga will collapse. -- John |
#9 posted 404 days ago |
Hi Scot, That’s a good looking work space. Nice job on the dust collection system, too. Lee -- by Lee A. Jesberger http://www.prowoodworkingtips.com http://www.ezee-feed.com |
#10 posted 404 days ago |
I have run it with everything closed with no problem. I believe you would have to get up to well over 5 HP to start having to worry about that. The blower on a DC is not a positive displacement air mover. It will reach a point to where all it does is just spin without increasing vacuum. On larger Industrial systems I could see where this could be an issue but they typically run from 15 to well over 100 HP systems. -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#11 posted 404 days ago |
I see way too many 90 degree elbows. You should have none, unless they are wide sweep. Use two 45s and a short straight section. |
#12 posted 404 days ago |
brtech, I do have more than I wanted, However to keep things close 45’s just were not working around the lights. But to account for the 90’s all of the ducting is 6” and I am getting excellent dust/chip removal at the jointer, table saw and planer. And the 3 HP DC is providing more than enough cfm’s. Other than coming into the CS I am using 45’s. -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#13 posted 403 days ago |
I’m got a few days off mid week next week so Hopefully I’ll get the next section done and post more pics. -- If the old masters had power tools, they would have used them. So get off your damn High Horse. |
#14 posted 402 days ago |
I think it’s a good looking installation…most importantly, you’re happy with it. It looks like your blast gates will have inserts instead of the sliding gate type. I need to do that on a few of mine where the slides project too far out of the gate body. -- I long for the days when Coke was a cola, and a joint was a bad place to be (Merle Haggard) |
| Forum | Topics |
Woodworking Skill Share
8846 |
Woodturning
246 |
Woodcarving
32 |
Scrollsawing
69 |
Joinery
96 |
Finishing
1599 |
3593 |
15980 |
Hand Tools
2097 |
Jigs & Fixtures
501 |
Wood & Lumber
2907 |
813 |
Focus on the Workspace
925 |
778 |
Woodworking Trade & Swap
2777 |
LumberJocks.com Site Feedback
1553 |
Coffee Lounge
6133 |
