Problem with Steel City Rable Saw 35601
Forum topic by Sac posted 107 days ago 237 views 0 times favorited 7 replies Add to Favorites
View Sac's profile
Sac
192 posts in 120 days
107 days ago
Hello Folks, I bought this saw about three months ago. It is replaced by Model Number: 35670. Well being I just finished pretty much setting up the shop/Garage I am starting to make some jigs. When I cut anything thicker than 1” this saw almost comes to a stop if I attempt to cut faster than an inch every 30 seconds. Well lerts just say it is slow like something is wrong. I’ve contacted Steel City and have yet to hear back from them. I had an electrician out last week to make sure the breaker box was prepared for the work I am going to do.
All breakers are 30 and 60 amp and we have 1- 220. The extension cords I messed around with and I have one that is approximatley 15 foot long 14AWG. It works best witht he saw.
Any ideas why this saw may be acting like this?
Thanks.
-- Jerry, Measure 10 times cut once. Set in the foothills of the Smokey's
View Greg Wurst's profile
Greg Wurst
414 posts in 319 days
107 days ago
You need a 12AWG extension cord. 14AWG is only good up to 10-15 amps. I would bet that extension cord is very warm to the touch.
http://www.askthebuilder.com/B174_Extension_Cord_Size_Chart.shtml
Also, I have to ask the obvious questions like is the blade sharp, how many teeth, crosscut or rip, etc.
View DaveH's profile
DaveH
241 posts in 265 days
107 days ago
Belts adjusted properly? Running with 110 or 220? Is the saw motor configured for 220 and your plugged into a 110? Did you verify the saw plug? Was it wired correctly?
-- Dave Herron, Boise, ID -- “That which does not crash the browser, makes it stronger”
View Ben Griffith's profile
Ben Griffith
35 posts in 166 days
107 days ago
I agree with Greg… the 14AWG raised a flag for me. I have the Craftsman badged version of that saw running at 110V from a 50’ 12AWG extension cord plugged into an outlet served by a 20A breaker. Eventually I plan to run some outlets to that side of the basement, but I haven’t had any problems with the extension cord setup.
Actually…. isn’t there something about smaller gauge wires being able to handle heavier loads at 220V than at 110V? Since at twice the voltage you only need half the current. So maybe it’s not the cord. But if it’s getting warm like Greg said then it probably is.
View ChicoWoodnut's profile (online now)
ChicoWoodnut
670 posts in 302 days
107 days ago
I’m betting the saw is set up for 220 and is only running on half a leg at 110.
View Sac's profile
Sac
107 days ago
Hello folks, Sorry but I had the guage wrong. I was thinking the 14 was the heavery. It is 12ga AWG. Umm I’ll re-check the saw and see if it is setup for 220 or not. The Belt idea I’ll check again as well. I’ve been over the manual this morning and haven’t found a thing wrong but I had not checked all of you all’s suggestions which I will head out to do now.
Thanks!
View Sac's profile
Sac
107 days ago
Ok it is all good now. What I found was the belt had slipped onto the spindle of the motor pully and was not on the pully itself. I tested the cuts and now I am excited about this saw! I just attached the side table and router as well. on to finishing some more jigs!
Thanks for all your ideas that led me to resolving this.
SaLuTe !!!!! To you all LumberJocks!
ChicoWoodnut
107 days ago
Glad it was that easy! Now go cut some wood. On second thought, take a deep breath and let the excitement wane first LOL. Don’t want any shop accidents.
Bookmark And Share This Page
