First time working rough lumber, advice.
Forum topic by Zboom posted 05-10-2012 03:35 AM 2186 views 1 time favorited 15 replies Add to Favorites Watch
View Zboom's profile
Zboom
72 posts in 2589 days
05-10-2012 03:35 AM
Hey all I just bought a ridgid 4331 planer and it is still in the box. I also bought a piece of rough cedar and need some tips on making dimensional wood out if it for a address sign for our house. I have read a lot but at this time I don’t have a jointer and I’m looking into building a sled for now. So my question is should I square the edges first and then joint the face of the board with my planer? Then plane it down to thickness? Thanks
Michael
-- Michael, www.facebook.com/flatlandersww
15 replies so far
View BilltheDiver's profile
BilltheDiver
260 posts in 3120 days
#1 posted 05-10-2012 05:20 AM
You have to start with squaring a face, rather than an edge. That means either building that sled, or using a router on skis. The planer only creates parallel surfaces, not square ones. Once you have a face prepared you can square the edges on a table saw with a jig, or on your router table with an offset outfeed fence.
-- "Measure twice, cut once, count fingers"
View JimDaddyO's profile
JimDaddyO
581 posts in 3314 days
#2 posted 05-10-2012 11:40 AM
Just like Bill says. Also, you need a flat face to put on the table side of the planer. If there is any cup in the wood, the pressure rollers of the planer will take it out before the wood gets planed, and when the wood is released from the rear pressure roller, the cup will spring back.
-- my blog: http://watertoneworkshop.blogspot.ca/ my You Tube channel: https://www.youtube.com/channel/UCA5AretE3xPoVDV61AxUdUA?view_as=subscriber
View knotscott's profile
knotscott
8173 posts in 3610 days
#3 posted 05-10-2012 12:06 PM
If the face isn’t flat, the squared edges won’t necessarily be a true 90° to the face, so flatten first. If you dont’ have a jointer, get one! (kidding) You can build a sled as you mention (good choice IMO), use a router jig as Bill mentioned, or use a handplane. Find some practice pieces rather than training on your purchased lumber.
Zboom
#4 posted 05-10-2012 07:16 PM
Thanks for the replies, it sure helps a lot. In yalls opinion is the planer sled a good idea or is the router “skis” a better idea?
View DS's profile
DS
3044 posts in 2655 days
#5 posted 05-10-2012 07:20 PM
With a thickness plane, but no jointer, you can get, or make, a straightline jig, then, if your rips aren’t too wide, you can run them on edge through the planer to clean them up. I built a lot of face frames this way before I got my jointer.
View Doss's profile
Doss
779 posts in 2499 days
#6 posted 05-10-2012 07:23 PM
How big is the piece and how much material do you plan to remove?
I use a router jig (rail-mounted bridge) on slabs I work with, but if it’s a small piece I would go ahead and use another method.
If the piece is too large (like my slabs), a planer sled is pretty useless due to the number of times I’d have to run it through to flatten (parallel to sled) the slab.
So… how big is the piece?
-- "Well, at least we can still use it as firewood... maybe." - Doss
Zboom
#7 posted 05-10-2012 07:51 PM
Hey DS do you have a pic of what a straightline jig would look like? Never seen one or heard of one.
Doss, the piece is approx 6 inches wide, 8 ft long, and an inch thick. I will probsbyl half the stick and just use 4 ft of it.
Cheers
View vonhagen's profile
vonhagen
541 posts in 2599 days
#8 posted 05-12-2012 12:29 PM
here is how a 4 sided moulder works, i joint one edge then rip it in the rough over size by 1/4 inch then set the moulder heads to the desired width and thicknes then set the infeed or jointing bed, there is a bed and a fence to the right. as i feed the board it first joints the bottom with the first head then the second head joints and squares the right edge then the third head mills the width and squares the left edge and then the forth head planes the top of the board to finished thickness. so joint the face first then joint one edge with the jointed face on the fence then rip to desired width then do the thickness on your planer
-- no matter what size job big or small do a job right or don't do it at all.
View Doss's profile
Doss
#9 posted 05-14-2012 03:58 PM
At that size vonhagen, I’d be tempted to just go buy a “cheap” benchtop jointer and be done with it. You can find them on craigslist or buy a new one for under $300. You can get a larger benchtop version for under $500 if that’s in your budget.
If you’re not working a lot of boards and don’t need 6+ inch wide boards, it’s probably the easiest way.
If that’s not sounding good to you, just build a nice sled for your planer and start running them through.
A jointer is going to save you a lot of time on boards of this size, but it does add additional costs and space requirements.
vonhagen
#10 posted 05-16-2012 08:04 PM
doss, i am just trying to explain the way large mills run their rough lumber and apply it to a small shop. if you are going to buy rough lumber instead of s3s or s4s the the basic machines to use are a jointer, table saw, and a thickness planer. you save lots of money by buying in the rough and buying pre milled lumber does not guarantee that the boards are not straight ,cupped, or twisted. if you read about the 4 sided moulder it does all 4 sides in 1 pass and i explained the sequence of the cutterheads to give zboom an idea of how to mill lumber. yes you can make a sled and shim the corners to try and flatten it out and use a straight edge to run it thru the saw but its more work than just taking it to a mill and have them dimension it for a few bucks. lesson here is dont buy rough lumber if you dont have the machines to mill it.
View DS's profile
DS
#11 posted 05-16-2012 08:20 PM
A straight line jig simply attaches your board, side by side, to another board that is known straight.
The two boards are passed through the TS together with the known straight edge against the fence.
This effectivly transfers the straight line to your board.
I forget where I got mine, but it is simply a pair of extruded aluminum clamps.
For the straight edge reference board, I typically use plywood cutoffs.
View Doss's profile
Doss
#12 posted 05-16-2012 08:23 PM
Hey, my fault on the false callout vonhagen, that was actually meant for Zboom.
I understood where you were coming from vonhagen... I have some homemade jigs and rigs to mill/finish my own rough cut lumber. Again, sorry for the confusion.
As an aside, one of my local shops has a crazy set of machinery that can make moulding (molding), floor boards, paneling, deck boards, etc. that I approached about milling some of my wood for me. The problem is they can’t handle 30”+ wide boards :-)
View ETwoodworks's profile
ETwoodworks
92 posts in 2928 days
#13 posted 05-16-2012 09:03 PM
You dont really need a straightline jig. What I do is hot glue a straight edge to the edge of the board and let the straight edge ride on the TS fence. Then you just pull your yardstick off and scrape the hot glue away. Cheep and easy.
-- Building quality in a throw away world.
View DS's profile
DS
#14 posted 05-16-2012 10:24 PM
ET… technically, that is still a straightline jig…
;-D
Zboom
#15 posted 05-31-2012 09:03 PM
Thanks for the help… I used a planer sled and got a flat face then used a piece of mdf for a straightline jig… I think it turned out well for my first time dimensioning lumber…
Cheers
