Having a hard time swallowing the Douglas Fir pill for my workbench.
Forum topic by TDog77 posted 05-10-2012 01:33 AM 12311 views 0 times favorited 27 replies Add to Favorites Watch
View TDog77's profile
TDog77
125 posts in 2345 days
05-10-2012 01:33 AM
I am getting ready to start my workbench and thought since this is my first one I really wanted to study the design, vises etc and read a couple short books and then just yesterday read Christopher Schwarz book (excellent read by the way) and have decided to build his rendition of The French Workbench which I think is very well thought out. My dilemma is the choice of lumber with not being able to get my hands on any Southern Yellow Pine like he has used on soo many of his recent benches and highly recommends. The choices in my area are Hem Fir and a few rarer selections of Douglas Fir and I am having a bit of a hard time accepting Douglas Fir as an option for at least the top of it but wow is it way cheaper then the maple or ash route. Now if some of you fellow jockers say go for it on the Fir since you have used it in this application before and you are happy with it then Ill probably go that route; but since I am going to be spending the time on it and want it to last a looong time then I also don’t mind doing at least the top in Maple if you think it is just that much better. Im not a cheap skate but if the maple really is not needed then I could put that savings towards some more tools.
Second are there any special considerations when joining too very different woods like a fir base and a maple top?
27 replies so far
View knotscott's profile
knotscott
8005 posts in 3369 days
#1 posted 05-10-2012 01:37 AM
Just so you know, my bench is hard maple, not fir, SYP, or hemlock. Fir and hemlock are a lot softer than maple, ash, oak, hickory, etc. Other’s opinions will likely vary, but I’m thinking if you’re going to the trouble to make a nice bench, I’d at least want the top to be made of a hard wood. You can use cheaper woods for the legs and support structure.
View rockindavan's profile
rockindavan
299 posts in 2629 days
#2 posted 05-10-2012 01:57 AM
I built my bench top out of maple and base out of cherry. I figured if I was going to spend a bunch of time building it I would spring for better quality and better looking materials. I guess it boils down to how much it means to you to have a nice looking bench. If you are not going to build a bench for at least another 10 years, I would suggest going for the maple. A bench is something you will use on every project where some tools are not used as often.
View tyskkvinna's profile
tyskkvinna
1310 posts in 2979 days
#3 posted 05-10-2012 02:20 AM
I actually love working with Doug Fir but I wouldn’t use it for the top. I’d be nervous about denting it too often, honestly. But I’ve glued it and joined it with maple just like any other woods and so far I’ve not noticed any issues.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View derosa's profile
derosa
1577 posts in 2829 days
#4 posted 05-10-2012 03:00 AM
For 70.00 on craigslist I bought enough white oak to build the top and several other projects and it wasn’t the absolute cheapest I’ve seen. I’ve also found ash, hemlock and hickory for really affordable on craigslist; keep checking the listings and the top might price out similar to pine.
-- --Rev. Russ in NY-- A posse ad esse
TDog77
#5 posted 05-10-2012 03:29 AM
How are you usually looking up lumber on craigslist because I look twice a week at least and have been doing so for about 6 months and only found a couple pieces of cherry? I usually use “lumber” “rough lumber” and “woodworking” for keywords.
View nwbusa's profile
nwbusa
1021 posts in 2279 days
#6 posted 05-10-2012 03:47 AM
My bench is doug fir for the base and hard maple up top. Ideally I’d have used maple throughout but yeah… It’s expensive.
-- John, BC, Canada
View MNgary's profile
MNgary
298 posts in 2410 days
#7 posted 05-10-2012 04:04 AM
My bench is the typical cabinet-maker style. I built it using construction grade 2×4’s (hemlock & fir) for the top and the base. After 15+ years it still meets my needs and if I were to build one again I’d use the same material. However, I first let the pieces air dry for a year.
-- I dream of a world where a duck can cross the road and no one asks why.
MNgary
#8 posted 05-10-2012 04:08 AM
View DKV's profile
DKV
3940 posts in 2497 days
#9 posted 05-10-2012 04:23 AM
I just received my 21st century bench plans and plan on maple for the top. The substructure will be whatever I can afford after buying the maple.
Don
-- This is a Troll Free zone.
View waho6o9's profile
waho6o9
8187 posts in 2570 days
#10 posted 05-10-2012 04:58 AM
Specify what you want on Craigslist in the search box on the left and make sure the menu is on sale, then
hit enter.
I usually put hardwood lumber, then hit enter. Or oak, maple, etc.
derosa
#11 posted 05-10-2012 04:59 AM
I go into the material section and then type in various woods, usually cherry, ash, maple, oak, locust and sycamore. Because the results are limited to just one location there usually isn’t enough listings and craigslist will show similar listings in the area. Might require a longer drive but this evening I found hemlock for 58 cents a BF, locust for a 1.50 a bf, red and white oak for 1.50-2.00 bf and cherry for 2.50. Just have to keep looking and it does show up. I’d also look for whatever the common local hardwood is. Cherry is common throughout this area and PA, unfortunately oak seems the most common, end result is some really cheap prices. The time or two I’ve seen redwood listed or spanish cedar the prices were outrageous in comparison.
TDog77
#12 posted 05-10-2012 01:01 PM
Where do yo find the materials section? If I type in Cherry in the for sale section for example it comes op with a ton of “cherry” including kids toys, vehicles etc. so if I could limit it to materials then the species keyword that would save some time for sure but I cannot find it.
TDog77
#13 posted 05-10-2012 01:02 PM
Nevermind….just found the materials.
View Bertha's profile
Bertha
13525 posts in 2686 days
#14 posted 05-10-2012 01:13 PM
TDog, I feel you. In the interest of saving time, I bought two 2 1/4 inch maple slabs from Grizzly to glue-up for the top. I started collecting my douglas fir stack, planning to build the undercarriage from it. Now the more that I look at it, I’m considering going all fir and using the slabs for something else. I passed this question around to all my buddies here and no one has given me a reason NOT to use fir. I think I’m going for it. If you do too, I’ll be looking out for yours!
View crashn's profile
crashn
528 posts in 2458 days
#15 posted 05-10-2012 04:04 PM
I search craigslist every 1/2 hour (phone app) and it alerts me when there are any results to several keywords
lumber
wood
woodworking
router
saw
bookcase
desk
sawmill
tree
etc….....
You have to be quick on CL, at least around here. Lots of competition.
-- Crashn - the only thing I make more of than sawdust is mistakes
