Need a 1/32" shim
Forum topic by Eric posted 05-09-2012 08:14 PM 2170 views 0 times favorited 14 replies Add to Favorites Watch
View Eric's profile
Eric
221 posts in 2509 days
05-09-2012 08:14 PM
Any suggestions for a home made 1/32” shim? Or better yet a 3/64” shim. Playing card? (2) playing cards?? What do you use?
-- Eric
14 replies so far
View Bill White's profile
Bill White
4929 posts in 3958 days
#1 posted 05-09-2012 08:25 PM
Shim for what?
Bill
-- bill@magraphics.us
View DS's profile
DS
2917 posts in 2418 days
#2 posted 05-09-2012 08:27 PM
Take a regular shim to the belt sander—done.
View Joao Araujo's profile
Joao Araujo
25 posts in 2831 days
#3 posted 05-09-2012 08:31 PM
Hello,
Aluminum pop or beer can !
Take care,
Joao Araujo
View sarahss's profile
sarahss
258 posts in 2647 days
#4 posted 05-09-2012 08:42 PM
a tounge depressor is about 1/16—a little light sanding is all it needs to get you where you want to be
View SnowyRiver's profile
SnowyRiver
51457 posts in 3478 days
#5 posted 05-09-2012 09:05 PM
If you have a sharp blade, you should be able to cut that on the table saw.
-- Wayne - Plymouth MN
View Sawkerf's profile
Sawkerf
1730 posts in 3066 days
#6 posted 05-09-2012 10:24 PM
I often use business cards, cardboard from bubble packed parts, those loose cards from magazines. For something more durable, you can make shims from plastic bottles.
View DKV's profile
DKV
3940 posts in 2501 days
#7 posted 05-09-2012 10:40 PM
Eric, now that you got me curious how thick is a playing card? Hard to believe but I do not have any in the house. Unless you count crazy 8 cards…
-- This is a Troll Free zone.
View DS's profile
DS
#8 posted 05-09-2012 10:43 PM
The only down side to using playing cards is getting half-way through the game only to find out some are missing!
That sucks… but on the bright side, the game table doesn’t rock anymore.
View mark4345's profile
mark4345
71 posts in 2420 days
#9 posted 05-09-2012 10:58 PM
scrap plywood veneers laying around?
Bill White
#10 posted 05-09-2012 11:04 PM
I certainly wasn’t tryin’ to be a smart a$$. Shims have different applications. Wood, metal, machines, etc.
Just wonderin’.
Bill
View handi's profile
handi
141 posts in 4437 days
#11 posted 05-10-2012 01:20 AM
For future reference, go to the local hobby store where they sell plastic model kits. They should have a display of styrene plastic sheets in all sorts of thicknesses from .005” on up. Easy to cut with a knife or saw and are pretty accurate.
Ralph
-- Watch Woodcademy free on Amazon Prime! www.woodcademy.com
View bondogaposis's profile
bondogaposis
4727 posts in 2348 days
#12 posted 05-10-2012 01:21 AM
A playing card is .01” use 3 or 4.
-- Bondo Gaposis
View Dusty56's profile
Dusty56
11819 posts in 3685 days
#13 posted 05-10-2012 01:26 AM
You stated the thickness and nothing else….what are you using it for ? what does it need to be made from ?
View Eric's profile
Eric
#14 posted 05-10-2012 02:41 AM
Used it for a spacer to drill parallel holds. Spacer seems to have worked fine. Thanks for the ideas!
-- Eric
