How to rejuvenate an old Machine - need advice please.
Forum topic by JRPortman posted 05-09-2012 04:36 AM 3742 views 0 times favorited 6 replies Add to Favorites Watch
View JRPortman's profile
JRPortman
17 posts in 2689 days
05-09-2012 04:36 AM
Topic tags/keywords: machine clean rejuvenate fix craftsman jointer planer molder rust oil grease question advice resource
I recently purchased a Craftsman 306.23377 Jointer Planer Molder on Craig’s List for $60 – it works, but is definitely in need of some TLC. Rusty surfaces, bone dry chain, etc. I’ve never fixed up an old machine before, and though i’m sure it needs grease and oil, i’m not sure which goes where and certainly don’t want to mess it up. Any advice or a resource that has info on this? thanks.
-- J.R.Portman, New Orleans, http://www.jrportman.com
View Loren's profile
10477 posts in 3887 days
#1 posted 05-09-2012 04:48 AM
Total score. You got the one with the 7” jointer on top and
the flip-up tables?
Also known as a Belsaw 805 or 684
http://www.belsaw.com/
#2 posted 05-09-2012 04:55 AM
I had one for awhile for a jobsite machine. It was
pretty capable despite some crude design elements.
#3 posted 05-09-2012 05:27 AM
Wd-40 is spray kerosene and pricey for what it is, but it
cleans out gunky mechanisms and cuts grease. You can
used that if needed to get things moving but do NOT,
whatever you do, squirt it into bearings unless you want
to shorten their life.
Bearings are probably fine but all those threaded rods will
be oxidized and so forth. Wire brush them and squirt them
with degreaser and wipe off as much of the rust as possible.
You may need to make a crank handle for the table as
they are often missing. A cheap-o socket meant for
removing spark plugs will if modified by cutting two
slots in it and you can use a speed-bar as your handle.
I would wax the threaded rods after you’ve got things
moving with the degreaser. The sprockets do well with
some grease.
JRPortman
#4 posted 05-09-2012 01:01 PM
Loren-
It has an 8” Jointer on top and flips open for the planer. Belsaw doesn’t list my model number on the site, but i might give them a call to see if the dust chute they sell will fit my machine, as i was planning on making one to fit myself. good call on the crank handle missing – was going to fabricate one from 1/2” pipe, but a spark plug remover sounds even better. Thanks for the cleaning recs as well – any particular brand of grease you recommend?
View Bluepine38's profile
Bluepine38
3380 posts in 3325 days
#5 posted 05-09-2012 01:47 PM
Start with the Sears and Belsaw sites and visit www.VintageMachinery.org and similar sites until you can come
up with a manual, unless you were lucky enough to get one with the machine. These older manuals usually
come with a parts breakdown and sometimes very good maintenance instructions. For threaded rods, I
prefer a dry graphite spray.
-- As ever, Gus-the 80 yr young apprentice carpenter
View chrisstef's profile
chrisstef
17800 posts in 3246 days
#6 posted 05-09-2012 02:48 PM
white lithium grease is also handy for those threaded rods.
