Resawing
« back to Hand Tools forum
Forum topic by Gerald Thompson posted 05-09-2012 12:15 AM 1329 views 0 times favorited 8 replies Add to Favorites Watch
Gerald Thompson
1142 posts in 2472 days
05-09-2012 12:15 AM
Topic tags/keywords: question
Would someone please give some advise on resawing lumber? I would be dealing mainly walnut and cherry. The lumber would range from 10-12’’ in width. I know I’m in for a workout. I can only do 6’’ on my band saw and it gets a workout even using a good blade.
-- Jerry
8 replies so far
View treerecycler's profile
treerecycler
6 posts in 2447 days
#1 posted 05-09-2012 12:23 AM
If someone has a small bandsaw sawmill close to you they might resaw it for you quite inexpensively.
-- Dave, Arkansas,retiree
View SASmith               's profile
SASmith
1850 posts in 3225 days
#2 posted 05-09-2012 12:28 AM
If you are talking about resawing by hand, I would cut from both sides with the tablesaw first. That would guide your hand saw blade and make for 6” that you don’t have to cut by hand.
-- Scott Smith, Southern Illinois
View Doss's profile
Doss
779 posts in 2502 days
#3 posted 05-09-2012 01:05 AM
If you’re cutting a lot of wood, I’d suggest getting a larger bandsaw. Even if you buy it and resell it, it may be worth it in the long run.
-- "Well, at least we can still use it as firewood... maybe." - Doss
Gerald Thompson
#4 posted 05-09-2012 01:12 AM
I did a searh on the subject. This I shoud have done before posting .”No way Jose!” I would not be saving that much wood. I could be putting things together instead of sawing, too much chance of error and it gets hot and humid in Fa.
-- Jerry
View AnttiN's profile
AnttiN
33 posts in 2453 days
#5 posted 05-09-2012 01:38 AM
Hi Jerry,
The best thing I’ve seen on resawing with a bandsaw is by the brilliant Matthias Wandel” in “this video he did explaining the fundamentals.
Good luck!
Antti
Gerald Thompson
#6 posted 05-09-2012 11:48 AM
Thank you Antti. That video enlightend me greatly.
-- Jerry
View Brandon's profile
Brandon
4152 posts in 3189 days
#7 posted 05-09-2012 12:01 PM
Great video! I learned a lot. Thanks for posting it, Antti.
-- "hold fast to that which is good"
View Doss's profile
Doss
#8 posted 05-09-2012 02:51 PM
Exactly why I bought a 19… to run low TPI, wide bandsaw blades.
I thought of it like my 66” chainsaw. If I’m not running full-skip, I have to seesaw the bar in the cut in order to remove the waste material.
Good vid.
