best wood for outdoor furniture?
Forum topic by FredIV posted 407 days ago 8719 views 0 times favorited 21 replies Add to Favorites Watch
View FredIV's profile
FredIV
95 posts in 587 days
407 days ago
Topic tags/keywords: cedar
Hey all,
My neighbor asked me to make her a buffet table/cabinet that will be used exclusively for outdoors. The location of this cabinet will be under a porch in the backyard, completely shaded by trees and the porch roof. The flooring is pavers and the unit will sit up against the back of the garage.
Now, I live about 5 miles from the ocean so we experience damp, hot, humid summers and cold winters. Basically, nothing lasts forever on long island.
My question is, what would be the best wood to use for this project considering our natural elements? I’ve considered using cedar as this is probably the least expensive. My other consideration is cypress, which is a little bit more expensive than cedar. Teak was another thought but that seems very expensive. Personally, I’m leaning towards cedar but thought I would get some expert advice.
The dimensions will be 6’ long x 22” deep x 32” high with an upper shelf built on top of the cabinet top. It’s not a small piece so I’m assuming that stabillity of the wood needs to be addressed as well.
Thanks so much!
Fred
21 replies so far
View BTimmons's profile
BTimmons
1163 posts in 682 days
#1 posted 407 days ago
It sounds like you’ve already got it narrowed down pretty well. I was looking at making some outdoor furniture a while back, and like you, I discovered that teak is obscenely expensive. Cedar would definitely be my choice. If humidity is a concern, perhaps an outdoor marine varnish would be in order. The kind used on boats should do pretty well for just furniture.
-- Brian in Arlington, TX - Laziness is the foundation of efficiency.
View David Craig's profile
David Craig
2128 posts in 1306 days
#2 posted 407 days ago
Another option you might consider is White Oak. It can handle the outside elements fairly well and has a nice look to it. It is a bit more expensive than Cedar but much less expensive than Teak.
View KenBry's profile
KenBry
449 posts in 644 days
#3 posted 406 days ago
Redwood if it’s near you.
-- Ken, USAF MSgt, Ret.
View AandCstyle's profile
AandCstyle
691 posts in 454 days
#4 posted 406 days ago
I second the white oak suggestion. It makes beautiful furniture, ala Stickley (although I might be prejudiced in that regard :D) and it is used to make Adirondack chairs so you know it is rot resistant.
-- Art
View canadianchips's profile
canadianchips
1781 posts in 1194 days
#5 posted 406 days ago
I would stick with cedar.
View Loren's profile
5030 posts in 1845 days
#6 posted 406 days ago
Cedar would be good. I’d use spar varnish on it.
View reggiek's profile
reggiek
2236 posts in 1467 days
#7 posted 406 days ago
There are several hard woods that can be used in this situation. The biggest damage to outdoor funiture comes from UV rays. Once these rays remove your protective finish….the other elements – heat/cold, damp/dry….will finish the work that the UV started.
That said, I have used walnut, maple, mahogany….etc..etc…for outside items with the caveat that I refresh the finish every 6 months to a year. I use a good penetrating oil finish as this is easier to apply and does not require re-sanding to apply (you can apply spar varnish over an old coat of spar…but the level of the finish will be unequal – this is because most UV tolerant finishes are made to flake away with contiuous UV exposure…this is so that the entire finish does not curl and peal away as non formulated interior finishes would). It is usually a very good idea to sand old coats of spar before applying a new coat.
My favorite outdoor funiture woods though are Redwood (1) – great stuff but can be expensive depending on the distance you are from California and Oregon. White Oak and Cedar (2) tied – both are awesome woods and both have their pros and cons. Mahogany (3) great outside wood – alot of wood boats are made from this and with new plantation woods – it is getting a bit cheaper to use. There are many more…but listing them would make this way to lengthy. Typically though, most hardwoods will work outdoors if you are diligent about keeping them oiled or finished…
View treerecycler's profile
treerecycler
6 posts in 406 days
#8 posted 406 days ago
White oak and cedar are good woods for this. For a finish I used a three part finish on my Potting Bench. It is made up of equal parts of tung oil, turpentine, and polyurethane. Keep it thin and let it soak in before wiping. Use as many coats as you like. It is very easy to touch up later.
-- Dave, Arkansas,retiree
View DYankee's profile
DYankee
2795 posts in 759 days
#9 posted 406 days ago
painted.
-- Shameless - Winner of two Stumpy Nubs Awards
DYankee
#10 posted 406 days ago
Honestly, all the woods mentioned above are good, but in the end they all grey/rot/ etc faster when not painted. A really good outdoor finish is to use exterior paint base paint without the tint added. The paint base has all the protective properties except the tint (tint blocks UV), but the other properties of the base paint does a pretty good job. Base paint without tint will dry clear even though it goes on kinda milky.
FredIV
#11 posted 405 days ago
Thanks for the replies and suggestions. Very insightful.
View patcollins's profile
patcollins
712 posts in 1062 days
#12 posted 405 days ago
Ipe, Black Locust, and Douglas fir are pretty good choices too.
View fuckoff's profile
fuckoff
157 posts in 491 days
#13 posted 405 days ago
I like cypress for outdoor projects.I’ve been getting rough cut cypress for $1.25 a board foot
View Bobmedic's profile
Bobmedic
270 posts in 999 days
#14 posted 404 days ago
Ipe or teak but they are expensive. Redwood and cedar are naturally durable woods as well as white oak.
-- Save lives, ease suffering, reduce morbidity and mortality, stomp out pestilence and disease, postpone the inevitable, and fake compassion. The Paramedics Creed
View John's profile
John
154 posts in 1781 days
#15 posted 404 days ago
Meranti
-- John, Long Island, NY
