Staining Veneer before putting it on
Forum topic by Mosquito posted 05-08-2012 03:57 PM 1488 views 0 times favorited 4 replies Add to Favorites Watch
View Mosquito's profile
9247 posts in 2227 days
05-08-2012 03:57 PM
Topic tags/keywords: question oak veneering
I apologize if this has been asked before, but I’m curious if you can stain veneer before putting it on a work piece?
It’s all flat surfaces, nothing fancy, just a box. Is it possible to apply some stain, let it dry for a while, and then put the veneer on? It’s PSA veneer, so I don’t think the glue bleeding the stain would be an issue. This isn’t something I’ve ever tried before, so I thought I’d ask if anyone else has any experience with it.
-- Mos - Twin Cities, MN - -
10106 posts in 3582 days
#1 posted 05-08-2012 04:03 PM
Shouldn’t be a major problem. Try it on a test board and
see how the process works out.
View tyskkvinna's profile
1310 posts in 2921 days
#2 posted 05-08-2012 04:21 PM
I like to do veneer with crazy dyes and I’ve learned it works best if I dye/stain it prior to glue. The handful of times I tried glueing first I ended up with a really inconsistent dye pattern later because it was saturated with glue.
The only thing I’ve learned to do special is just keep an eye on it right when you attach it and wipe out / even away any glue immediately.
-- Lis - Michigan - -
View RussellAP's profile
3103 posts in 2221 days
#3 posted 05-08-2012 04:30 PM
I think it depends on how you’re gluing your veneer. If you use contact cement, or white glue. White glue gets the boards wet so I would stain after it dries.
#4 posted 05-08-2012 04:34 PM
It’s PSA veneer, so glue shouldn’t matter. It’s sounding like I should be ok. Thanks everyone for your input. The main reasoning was because the stain would have a red tint to it, and I don’t want to get any on the curly maple that will be acting as the ‘front’ of the box.
