New Table Saw - how to protect the table from rust?
Forum topic by Mike posted 380 days ago 1017 views 0 times favorited 23 replies Add to Favorites Watch
View Mike's profile
Mike
60 posts in 380 days
380 days ago
Hi Guys, just bought my new saw and am wondering, what does everyone do to combat rust on the table. My drill press table was nice looking for about a year, and I began to get lazy about oiling the table and now it’s all rusty. I don’t want that happening to me new saw. If it helps, my show is in my basement so it tends to get humid during the summer months. Thanks for any advice!
Mike
23 replies so far
View AJLastra's profile
AJLastra
86 posts in 399 days
#1 posted 380 days ago
I’ve regularly use a product called “TopCoat” you can find it at Woodcraft, Rockler, Woodworker’s Supply. when you spray it on, let it turn white before you buff it off. It works great. What I dont like about it is that the surface you apply it to isnt as slick as it is if you just apply something like Johnson’s paste wax and buff it out.
View crank49's profile
crank49
2289 posts in 1142 days
#2 posted 380 days ago
I have always used Johnson’s paste wax and no rust after 2 years in the basement in Tennessee.
-- Michael :-{| Diapers and politicians both need to be changed often; and for the same reason.
View Bill White's profile
Bill White
2607 posts in 2131 days
#3 posted 380 days ago
Mike, you can spend a bloody fortune on chemicals if ya want. I just use a paste wax. Mississippi has its share of humidity in case ya didn’t know, so I wipe the surfaces with a solvent, dry ‘em with a paper towel, wax and buff. Do this 2 or 3 times a year (my way).
If something gets funky, use a non-woven pad to super clean. Then use the solvent/wax process.
Oh, I forgot. LAZY is an element of shop life.
Bill
-- bill@magraphics.us
View Jeff in Huntersville's profile
363 posts in 1365 days
#4 posted 380 days ago
Good old Johnson’s paste wax is the way to go and a small tub will last for years.
View Loren's profile
4893 posts in 1819 days
#5 posted 380 days ago
View Roswell's profile
Roswell
64 posts in 489 days
#6 posted 380 days ago
Hey Mike,
I’ve not used it myself, but several of the guys I know down here in Florida are big fans of Boeshield their tablesaws and such. I’ve got horribly acidic skin, and i leave rusty fingerprints on everything I touch unless I clean it. Hopefully this stuff will reduce my cleanup time.
-- _Never argue with an idiot. They'll just drag you down to their level and beat you with experience_
View dhazelton's profile
dhazelton
832 posts in 467 days
#7 posted 380 days ago
A dehumidifier can’t hurt either. Remember that all the screws and trunions on a saw will go unprotected.
View Earlextech's profile
Earlextech
599 posts in 861 days
#8 posted 380 days ago
paste wax
-- Sam Hamory - The project is never finished until its "finished"!
View Bobmedic's profile
Bobmedic
270 posts in 972 days
#9 posted 380 days ago
T-9 Boeshield
-- Save lives, ease suffering, reduce morbidity and mortality, stomp out pestilence and disease, postpone the inevitable, and fake compassion. The Paramedics Creed
Todd A. Clippinger
8654 posts in 2270 days
#10 posted 380 days ago
The more you use it the less rust will form;)
View Mike's profile
Mike
#11 posted 380 days ago
Thanks everyone for your replies. I already have a tub of Johnson paste wax so I’ll give that a go. When I put the saw together I used a few rags to wipe all the oil off the table. It’s pretty clean now so do you think I can wax right over it or should I strip the steel with something like lacquer thinner and then apply the wax? I’m a reloader also and always use lacquer thinner to clean oil off new dies so I assume that’ll work on the saw table (with basement windows wide open!). :)
View William's profile
William
7101 posts in 1013 days
#12 posted 380 days ago
I also use Johnson’s Past Wax and am very happy with it.
I have to disagree with the statement someone made about a tub lasting for years though.
I go through a can about every month.
Of course I use it for everything under the sun though.
Just for one example, wax a saw blade and see what difference it makes in cutting.
I also use it as a finish on some projects too.
Nowadays, I keep two cans around. I label one for metal to be used on things such as tools and table saw tops. The other is labeled wood to be used on things such as handles and projects. I do this because I learned the hard way what happens if you accidentally get some metal residue, rust, or dirt in the can and then try to use it on a project. It is not pretty and hell to get cleaned back up to start over.
William
#13 posted 380 days ago
On a new tool I clean mine with sandpaper. I’m talking about something super fine like you’d use before applying paint to an automobile. I do this just to make sure it is super smooth. Then I spread it on and let it sit for a bit. Then I buff it with a rag. This make for a protected surface that is also slick. The slick surface has the added advantage to making it easier to handle heavier material on your saw. If you’ve ever used a saw that was rough and then try this method, you won’t believe the difference.
I meant to also put in my previous response, try waxing hand saw blades with Johnsons. It makes using them way more easier.
View jumbojack's profile
jumbojack
681 posts in 795 days
#14 posted 380 days ago
I’ll chime in with good old Johnsons.
View Martyroc's profile
Martyroc
2708 posts in 477 days
#15 posted 380 days ago
Here’s what I do, never leave wood on top of the saw, or sawdust for that matter. I use butchers wax once a month or more if I have been working in the shop a lot. My TS is 23 years old, I would love to get a new one, but it still looks, no rust and works almost as good as the day I got it, oh yea and the 14 hours it took to assemble it, still resonates with me.
-- Martin ....always count the number of fingers you have before, and after using the saw.
