Can you put lacquer over Danish Oil?
Forum topic by chadgr posted 05-08-2012 06:12 AM 2572 views 0 times favorited 3 replies Add to Favorites Watch
View chadgr's profile
chadgr
89 posts in 2181 days
05-08-2012 06:12 AM
Topic tags/keywords: question
I am just wondering if i can spray lacquer over a danish oil?
-- Chad Griffiths Vist my Etsy Shop https://www.etsy.com/uk/shop/Everythingwood1?ref=si_shop
3 replies so far
View AJLastra's profile
AJLastra
87 posts in 2198 days
#1 posted 05-08-2012 03:49 PM
here’s the “deal” You can apply ANY topcoat over ANY undercoat provided the undercoat is DRY, DRY, DRY. Are you going to spray the lacquer or brush it? My suggestion to you is this. If you want to….....and I presume you do….....avoid fisheyes in the lacquer topcoat, you need to seal the oil surface first. I would let the oil dry at least a week. Then I would apply a coat of Sealcoat shellac, which is dewaxed. That should dry hard within an hour. LIGHTLY scuff sand the shellac, then you’re goo to go with your lacquer topcoat.
chadgr
#2 posted 05-08-2012 04:37 PM
ok thank you for the useful tip
View Bill White's profile
Bill White
4910 posts in 3930 days
#3 posted 05-08-2012 04:51 PM
Dry/cure until ya can’t smell the finish. The nose knows…...
Then have at it. I agree with the shellac. I use it a bunch.
Bill
-- bill@magraphics.us
