Metric Chisel Question
« back to Hand Tools forum
Forum topic by Texchappy posted 05-07-2012 03:38 PM 1304 views 0 times favorited 2 replies Add to Favorites Watch
View Texchappy's profile
252 posts in 2151 days
05-07-2012 03:38 PM
I’m reading The Anarchist Tool Chest and wondering about my first tool purchase – a 6mm Japanese chisel. Schwartz mentions the drawback is that they are metric in an American imperial measure woodworking shop. When I got it figured that it would be ‘close enough’ to 1/4”. Did I figure wrong. I can see where it would be inconvenient with a mortise chisel but what about a bench chisel (or any chisel)?
Thanks in Advance,
-- Wood is not velveeta
2 replies so far
View tenontim's profile
2131 posts in 3675 days
#1 posted 05-07-2012 03:48 PM
If you cut your mortises first, which is what I do, it doesn’t even matter if your mortising chisels are metric. I have some Japanese chisels, and some Narex chisels, which are also metric, even though they’re marked with fractional sizes. If you are trying to clean up mortises that you cut with a mortising machine, you’ll find the metrics don’t quite fit.
View David Kirtley's profile
David Kirtley
1286 posts in 2928 days
#2 posted 05-07-2012 04:43 PM
You make your mortises and tenons to fit your chisels. The actual width only matters if you are trying to match up to some other width cutter.
-- Woodworking shouldn't cost a fortune:
