Laminated panels 30" x 24" x 1" thick
Forum topic by dustywalnut posted 05-07-2012 02:26 PM 1143 views 0 times favorited 3 replies Add to Favorites Watch
View dustywalnut's profile
dustywalnut
3 posts in 2263 days
05-07-2012 02:26 PM
Topic tags/keywords: plywood laminate glue up panels veneering joining
I work for a pipe organ company and we often make laminated 5-ply glue up panels for the consoles. We normally make the panels with 3 inner layers of poplar and walnut outside layers. Alternating the grain by 90 degrees for each layer. These panels are drilled with many 7/8” holes in a pegboard like pattern and need to stay stable for many years.
My question is: Will our 5-ply glue up method work for panels this large or should I be using another method?
One thought I had was to use voidless birch ply of 1/2” or 3/4” and glue walnut to both sides. Any thoughts or suggestions would be appreciated.
3 replies so far
View Bertha's profile
Bertha
13529 posts in 2745 days
#1 posted 05-07-2012 03:15 PM
I’m no expert in lamination but I can’t see how your typical glue up wouldn’t work. I’ve never seen a poplar core like you describe and I’d be looking to use a voidless ply if it were my project. I hope you post it when you’re done!
View MrRon's profile
MrRon
4853 posts in 3295 days
#2 posted 05-07-2012 06:54 PM
You may be better off laminating two 1/2” Baltic Birch panels together. It’s the 5-plys that worries me. With the BB, you will get 18 plies + two Walnut plys.
View vonhagen's profile
vonhagen
539 posts in 2417 days
#3 posted 05-12-2012 12:32 PM
lumber core ply
-- no matter what size job big or small do a job right or don't do it at all.
