BLO on Walnut??
Forum topic by jPell posted 379 days ago 956 views 0 times favorited 9 replies Add to Favorites Watch
View jPell's profile
jPell
25 posts in 835 days
379 days ago
Hi all. I have made some flooring transition strips out of walnut and was pondering on the idea of applying BLO before a few coats of poly to add depth. Any thoughts/input on this? Thanks in advance.
9 replies so far
View BTimmons's profile
BTimmons
1084 posts in 653 days
#1 posted 378 days ago
It’ll definitely add color depth. I don’t see any reason why it wouldn’t work, as long as you stick to the drying times recommended for each product. As always, test on scrap first.
-- Brian in Arlington, TX - Laziness is the foundation of efficiency.
14855 posts in 2386 days
#2 posted 378 days ago
It will certainly work. As Brian said, test a piece to make sure the result is what you want. I love BLO on walnut, but it does tend to darken the color.
87068 posts in 1745 days
#3 posted 378 days ago
I think you would do much better to use a product like Arm-R-seal rather than Blo
View Don W's profile (online now)
Don W
9947 posts in 735 days
#4 posted 378 days ago
blo works well on walnut.
View NathanAllen's profile
NathanAllen
383 posts in 1312 days
#5 posted 375 days ago
Tung Oil if you have the time. Since it doesn’t yellow the walnut will stay wet brown looking.
View Scot's profile
Scot
344 posts in 1564 days
#6 posted 375 days ago
I second the Tung oil
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
View crashn's profile
crashn
507 posts in 633 days
#7 posted 375 days ago
Here is a box in walnut, with BLO then wipe on poly over the top.
-- Crashn - the only thing I make more of than sawdust is mistakes
View enurdat1's profile
enurdat1
97 posts in 414 days
#8 posted 375 days ago
3rd on the Tung oil. I love the finish it gives. Behlen is my prefered brand.
-- It is what it is...
jPell
#9 posted 375 days ago
Man, where were you Tung oil fans yesterday?? Just kidding. I ended up making a thirds blend of BLO (mainly because that’s what I had on hand), Poly and Mineral Spirits (a little stronger on the MS) and did a few coats with that. Looks and feels amazing though I do wish it would have darkened up just a little bit more. I’m going to mix up another blend a little stronger on the Poly for the couple last coats. For now… I think I’ve found a new love. I will be trying the Tung oil on my next project though. Thanks everyone for your input.
