Cutting laminated corrugated cardboard
Forum topic by Derek Lyons posted 05-06-2012 06:04 PM 4043 views 0 times favorited 4 replies Add to Favorites Watch
View Derek Lyons's profile
Derek Lyons
584 posts in 3536 days
05-06-2012 06:04 PM
A friend is building a project from laminated sheets of corrugated cardboard, and made a couple of pieces too big… She’s asked for me to help in cutting them.
Basically, I’m trimming a four layer thick round sandwich of cardboard down about an inch to match a circle of luan plywood… I’m thinking a jigsaw with a very fine tooth blade is the best option.
Thoughts?
-- Derek, Bremerton WA --
View GodofBiscuits's profile
GodofBiscuits
97 posts in 3043 days
#1 posted 05-06-2012 06:14 PM
Nothing beats a good sharp blade and a straight edge on cardboard but you might be able to get a clean cut on th scrollsaw if the pieces aren’t too large for it. If you have a bandsaw with a fine tooth blade that may also word for you.
Good luck,
Jeffrey
-- Are you going to use that piece of scrap?
10278 posts in 3616 days
#2 posted 05-06-2012 06:17 PM
#3 posted 05-06-2012 06:20 PM
Try grinding and honing a regular worn out jigsaw blade to
a knife edge. Test it. The teeth of a blade will likely
tear the top of the cardboard a lot. A sacrificial piece
on top can prevent that but it should probably be something
denser like matte board.
View gfadvm's profile
gfadvm
14940 posts in 2658 days
#4 posted 05-07-2012 01:40 AM
I’ve cut a lot of corrugated cardboard on my tablesaw ranging from 1/4” to 1” thick. Used a 40 tooth blade and a zero clearance insert. Edges were much cleaner than I expected.I’ve used Loren’s tip to cut high density closed cell foam and it works great for that.
