Making a Longworth chuck
Forum topic by Jim Jakosh posted 382 days ago 2043 views 5 times favorited 11 replies Add to Favorites Watch
View Jim Jakosh's profile
Jim Jakosh
7309 posts in 1276 days
382 days ago
I just got interested in a Longworth chuck and thought It might be nice to have one for my lathe. I found this site on the web with a step by step plan for making an 8 pin chuck that took all the mystique out of it. He shows the layout of the slots which was the biggest mystery for me.
Here is is:
http://www.woodworkersguide.com/2010/10/17/how-to-make-a-longworth-chuck/
enjoy….........Jim
-- Jim Jakosh.....Practical Wood Products...........Learn something new every day!!
11 replies so far
View Mickey Cassiba's profile
Mickey Cassiba
315 posts in 1202 days
#1 posted 382 days ago
Excellent Jim! Thanks for posting this.
-- One of these hammers oughta fix that...
HillbillyShooter
1363 posts in 463 days
#2 posted 382 days ago
Although I’m not a turner, that Longworth chuck is really cool and looks like a lot of fun to layout and build. Good luck and thanks for sharing.
View Roger's profile
Roger
9191 posts in 974 days
#3 posted 382 days ago
Hey Jim. Thnx for the link Very good
View poopiekat's profile
poopiekat
2838 posts in 1905 days
#4 posted 382 days ago
Now I can take some of those ‘failed’ projects and finish them! Having this chuck will definitely be a problem-solver! Thanks for posting!
View rance's profile
rance
3856 posts in 1331 days
#5 posted 382 days ago
Nice layout technique. Seems pointless to bring in the four slots in further than the others though. That part of the slot will never be used and also weakens the piece. Unless of course you remove the four other knobs when using that inner part.
TopamaxSurvivor
13194 posts in 1846 days
#6 posted 382 days ago
Thanks for the tip! That makes it very simple and easy! ;-)
Jim Jakosh
#7 posted 382 days ago
Hi Rance. I think that you can just use 4 pins on a smaller diameter with the deeper slots. I’ll have to lay one out to see if that is true. I did lay out a 6 pin chuck using his technique and I think that is the way I will go. I’m still thinking about making every other slot short on the 6 pin one. It looks like it will be strong enough if I don’t.
I was thinking about Corian for the plates. It is flat and stable and can be cut easily. I have to find a flange with a 1”-8 thread to get started.
............Jim
View peteg's profile
peteg
2279 posts in 993 days
#8 posted 381 days ago
These are handy Jim, I dont have one myself however, they do make it super easy to centre up and hold a bowl to finish of ther bottom. I’m sure a lot of the guys will have a go at this one, easy to make. I did make an oversized set of coles jaws when I had a patch of making irregular or wainey edge bowls.
BTW Jim, Just managed to score a rotary vane oiless Gast vacuum pump that had become surplace to a job (best part it’s free) so having a lot of fun making several vacuum chucks, dont know how I went so long without one.
Catch ya mate
Pete
View sedcokid's profile
sedcokid
2508 posts in 1769 days
#9 posted 381 days ago
Looks great Jim, thanks for the post.
Thanks for sharing
-- Chuck Emery, Michigan,
Jim Jakosh
#10 posted 381 days ago
Pete, that is cool to have a vacuum chuck. I’ve seed a few in use and they are slick to work with!!
Jim Jakosh
#11 posted 377 days ago
Well I made a flange today- could not find one that I wanted with enough “meat” to it for all the holes I put in it.
It has 1”-8 thread 1 1/8 deep and the whole thing is 1 3/8 thick and 3 1/4” diameter with 8 1/4-20 holes in it. I laid out the plates in Corian and I’m having them cut at the Geek Group here in Grand Rapids on a CNC router to make them perfect. I was thinking I could do it with a router and pivot pin, but I would have needed a clear base plate to see through to stop the cut in the right place.
I saw one at our guild meeting on Tuesday and it was made from 2 sheets of 1/2” phenolic which looks like a good way to go- stronger than Corian and more stable than wood. I may have to make another bigger one…..........Jim
