Ridgid R4512 Squeel On Startup
Forum topic by BENGOR posted 379 days ago 952 views 0 times favorited 10 replies Add to Favorites Watch
View BENGOR's profile
BENGOR
4 posts in 396 days
379 days ago
Topic tags/keywords: ridgid r4512 squeel grinding noise
Hey guys! I am relatively new to LumberJocks, but I had a question for all of you. I recently purchased the Ridgid R4512 model table saw, and I just got a chance to assemble it today. So far, I love it! I assembled it all and it looks perfect and when I turned it on for the first time, it purred beautifly. As I was making a few test cuts, the saw was working just fine, but when I changed the blade bevel to do a few practice 45 degree cuts, the saw made an aweful squeel when I powered it on. The squeel lasted about 1-3 seconds and throughout the time the motor was on, there is a lighter squeel/grinding noise. When I powered the saw back down, there was a metalish grinding sound when the blade was about 4 or 5 seconds from being completely stopped. I reset the blade angle to 90 degrees, thinking that would fix whatever was making it make that sound, but the squeel is still there and so is the grinding sound when the blade slows.
Please help! The saw was literally assembled for an hour before the sound started!
Any help would be great!
10 replies so far
View knotscott's profile
knotscott
4186 posts in 1543 days
#1 posted 379 days ago
Sounds like bearings to me. The squeeling could also be belt, but the belt wouldn’t make the metallic grinding noise. How does it sound when you turn the blade by hand (with the saw unplugged)?
View Howie's profile
Howie
2449 posts in 1090 days
#2 posted 379 days ago
Anything fall down into the saw around the blade and rubbing against it?
-- Don't rollerskate in a buffalo herd
View nwbusa's profile
nwbusa
867 posts in 453 days
#3 posted 379 days ago
Could be several things, but the squealing/grinding sound ain’t normal (I have this saw and it runs smooth as silk).
Check to a make sure you got the foam packing block out from on top,of the motor when you assembled the saw. It’s hard to see and might have slipped into a moving part.
-- John, BC, Canada
BENGOR
4 posts in 396 days
#4 posted 379 days ago
knotscott – When I turn the blade when the saw is off, there is no noticeable grinding or any noise except for some very subtle squeaking. The blade doesn’t seem to wobble and there is clearly nothing rubbing against the blade. I removed the back panel to get a better look at things, but since I don’t know much about table saw motors, everything looked fine. The belt was nice and tight and there also was no noticeable wobble to the belt or pulleys when I manually turned the blade.
Howie – Nothing has fallen into the blade and I made triple sure about that.
nwbusa – I removed the Styrofoam while I was assembling it, so its not that.
I recorded the sound it is making and uploaded it to YouTube, here is the link: http://www.youtube.com/watch?v=Ky6IH0JczDE&feature=youtu.be
View RussellAP's profile
RussellAP
2394 posts in 454 days
#5 posted 379 days ago
Sounds like there is either some debris or play in the 51 080035003016 Arbor Pulley. http://www.mastertoolrepair.com/images/RIDGID_parts_R4512_saw.pdf
-- Failure does not stop me, it makes me try harder..... because I'm crazy.
RussellAP
#6 posted 379 days ago
If you look at the link http://www.mastertoolrepair.com/images/RIDGID_parts_R4512_saw.pdf the problem sounds like it’s between parts number 52 and 63. Most likely an arbor bearing due to a bad bushing or shim letting some dust in there, or just a factory part problem. I’d call them and send the sound link in an email. They will likely send you some parts free.
RussellAP
#7 posted 379 days ago
I have this saw, so I’m familiar with the sounds it makes. Yours sounds like when the power is turned on, it has a stuck bearing which frees itself of the shaft seconds after you start it. Then it intermittently sticks while the blade is turning. Then when you power it down, the torque is coming from the opposite direction, blade to motor and you dont hear it as much. While it’s idling down, the motor releases the torque and the bearing or bushing starts to make noise again.
I doubt you’ll be able to see anything happening, but if you take the arbor apart you’ll see what’s been happening. I wouldn’t use it until you get that fixed. It’s really a much quieter saw than that.
RussellAP
#8 posted 379 days ago
Sorry about all these comments, but if you call Ridgid and let them listen to the sound, they’ll probably send you 080035003701 Arbor Assembly. Or you could return it, which is a pain. I actually had to remove the motor assembly from my 4512 to get the thing out of the box because I had no help, very heavy unit.
knotscott
#9 posted 379 days ago
Try running it without the blade and see how it sounds.
BENGOR
4 posts in 396 days
#10 posted 377 days ago
Well, thanks everyone for the help and input! I contacted RIDGID and they said that the sound was coming from either the belt or the motor, and since I couldn’t figure out how to remove the belt, I contacted Home Depot. Home Depot has been very helpful in this situation and have agreed to swap out the cabinet part of the saw with another one that they have on hand. Thanks again for all your suggestions! What a great and helpful community! :)
