Need advise on finishing bar top
Forum topic by Shan posted 383 days ago 1665 views 0 times favorited 10 replies Add to Favorites Watch
View Shan's profile
Shan
30 posts in 1376 days
383 days ago
Topic tags/keywords: tiger maple epoxy topcoat top coat popping popping the grain curly maple quilted maple figured maple maple tiger curly figured bar bartop pour epoxy finishing
I am finishing a tiger maple bar top and want to pop the grain. I plan on using trans-tint dye to start the grain popping process. I have heard that I should then use boiled linseed oil to really pop the grain. My concern is that I plan on top coating with a 2 part clear epoxy, and I am wondering if it will adhere to the top once the BLO dries. Do I need to they apply shellac or can I go straight to the epoxy. Any advise this or any other part of finishing the bar top would be great.
Shannon
-- SeeWhatISaw
10 replies so far
View killerb's profile
killerb
147 posts in 569 days
#1 posted 383 days ago
Please don’t use linseed oil. Use a good drying oil, satin arm r seal is a good choice. It will do way more then blo. Give it 24 hours to dry and then coat with your epoxy. I use a post catalyzed lacquer for tops. Much faster and nicer then epoxy, but it has to be sprayed.
bob
-- Bob www.bobkloes.com
View Shan's profile
Shan
#2 posted 382 days ago
Want to use epoxy. You recommend a poly blend rather than shellac?
-- SeeWhatISaw
killerb
#3 posted 382 days ago
Arm R seal is urethane. Just works very well. Don’t use blo.
View CharlesNeil's profile
CharlesNeil
856 posts in 2041 days
#4 posted 382 days ago
Killerb nailed it, Arm r Seal, or even a coat of seal coat shellac will pop it really well, BLO is not a good choice, not these days, most of it, is missing the “B” part, rather than boiling it they just add some japan drier and it doesnt dry very well, personally I have no use for it, its just cheap, about all the good I can say about it, its not durable , and a very inferior finish, despite its popularity, it makes wood look great, but if and when it dries its a different story.
View HoBoMoNK's profile
HoBoMoNK
1381 posts in 2298 days
#5 posted 382 days ago
My family was in the restaurant business. I’ve used the following product many times to finish/re-finish commercial bar tops.
BEHLEN Rockhard Table Top Varnish
-- 温故知新
killerb
#6 posted 382 days ago
They have changed the formula on the table top varnish. It is not the same product. bob
View Clint Searl's profile
Clint Searl
849 posts in 532 days
#7 posted 382 days ago
If you’re using a dye stain, nothing more is necessary to emphasize the grain. Wet the dyed wood with naptha or acetone to see what it will look like with the epoxy, adjust the dye accordingly, and proceed to the epoxy. An intermediate coat of anything won’t improve the appearance. Save the BLO for starting fires.
-- Clint Searl.............We deserve what we tolerate
View Don W's profile
Don W
9964 posts in 738 days
#8 posted 381 days ago
I’m a big BLO fan, but it doesn’t do well on maple. Go with one of the bar sealers recommended above.
View olpuppy's profile
olpuppy
12 posts in 349 days
#9 posted 337 days ago
How did your bar top come out? What did you finally do in the finishing process? My methods are almost exclusively Lacquer (sprayed) and Zylene/Rudd stains on hardwoods.
-- olpuppy
View Shan's profile
Shan
#10 posted 95 days ago
Did the epoxy. Looks incredible. Bar is almost done. Will post photos when done.
-- SeeWhatISaw
