Stanley #46
« back to Hand Tools forum
Forum topic by Texchappy posted 05-03-2012 11:34 PM 2869 views 0 times favorited 10 replies Add to Favorites Watch
View Texchappy's profile
Texchappy
252 posts in 2243 days
05-03-2012 11:34 PM
There’s an auction ending soon on a Stanley 46. I’ve been eyeing a plow plane. This would be my first plane. Good choice. It appears to have a good set of blades with it.
-- Wood is not velveeta
10 replies so far
Texchappy
#1 posted 05-03-2012 11:35 PM
Just went back and read, just has one blade but still might be worth it to me if I can get more blades.
Texchappy
#2 posted 05-04-2012 12:50 AM
Didn’t get it. Guess if anybody reads this I’ll turn it into a recommend a plow plane thread. So anybody recommend a plow plane?
View Arch_E's profile
Arch_E
48 posts in 2544 days
#3 posted 05-04-2012 01:03 AM
Well, the #46 is skewed; so, it’s not easy to recommend something else like it that’s readily available. And, it’s a blessing perhaps that you didn’t get it with only having the one blade. Buying blades for that plane can be quite pricey.
OTOH, I’m a happy #45 user. A GOOD one with blades will set you back about $200. However, I tried my friend’s new LV small plow plane and it’s awesome—but more expensive. And, it’s idiot proof!!!! Unlike the #45 which can be tricky to set up. I’d strongly urge you to consider the LV on this one.
View Brandon's profile
Brandon
4152 posts in 2973 days
#4 posted 05-04-2012 01:09 AM
I’ve been eyeing the Veritas small plow plane for awhile—-just have other things that are higher on the list. I get by with a Stanley 45. You might also look into Record 44s. Good luck!
-- "hold fast to that which is good"
Texchappy
#5 posted 05-04-2012 01:56 AM
Seen the LV and it does look like what I need. Price scared me off for now though.
View Loren's profile
10476 posts in 3670 days
#6 posted 05-04-2012 02:09 AM
I had a #46 for a few years. Neat plane. The planes aren’t worth
much… it’s the sets of irons that are. When I had mine
there were no reproduction irons on the market – I think there
are now.
This guy claims to sell a set of new irons for $200
http://www.brasscityrecords.com/toolworks/Jim_Reed%20blades.htm
View killerb's profile
killerb
150 posts in 2420 days
#7 posted 05-04-2012 12:43 PM
46’s make nice dado planes. Can’t do that with a straight bladed 45. The nice skew set helps a lot. bob
-- Bob www.bobkloes.com
View Robert Brown's profile
Robert Brown
151 posts in 2714 days
#8 posted 05-04-2012 05:39 PM
I have a #46 and like it. It cost less than $50. From eBay I got a set of new blades for almost $100. There were no other bidders for the blades. I bought 3 each #46’s. Two of them very rusty and with incomplete accessories. The third with a broken body and some accessories. All three for less than $50 combined but bought over a period of several months. A lot of cleaning and some mix and match ended in one complete set and nearly complete second set.
But with all that said, I would not buy one as my First Plane. There are other types. First you went dado then plow. Maybe a little research is in order. Otherwise a lot of money can easily be spent due to ignorance.
I am assuming that you are new to using hand planes, if not I apologize. But if you are new. I suggest you start with an inexpensive block plane. Learn how to use it and sharpen it before moving on to more specialized and more expensive planes.
Texchappy
#9 posted 05-04-2012 05:43 PM
@Robert Brown: You are correct that I am a new hand plane user. I will take what you said into consideration. I’m doing research now which was part of the reason I asked. Started looking at plow planes because I wanted to cut a grove and didn’t want to saw and pare it all out.
Robert Brown
#10 posted 05-04-2012 09:46 PM
Texchappy, you came to the right place. There are many knowledgeable people here. A lot more so than I am. Enjoy the LJ site. I hope you find what you are looking for. Much of what I have learned about woodworking with hand tools came from here.
