A kind of rare planer.
« back to Hand Tools forum
Forum topic by RussellAP posted 05-03-2012 07:10 PM 1814 views 0 times favorited 11 replies Add to Favorites Watch
View RussellAP's profile
RussellAP
3104 posts in 2526 days
05-03-2012 07:10 PM
This is the first planer I bought. It was in an antique store in Jamesport Mo. $18
It’s a Stanley no35 Smooth plane 9”L, 2”W, 3 1/4lbs, 1870-1942.
I’ve taken it apart and cleaned and filed some grime away. The wood has no splits, and the metal no pits. Looks like it’s been kept warm and dry for a lot of years.
I use it all the time, it and my Stanley No5.
Found this verbiage with the pic.
This smoothing plane, as well as the #36, has a tote. How can this plane, whose length is equal to the #23, have a tote whereas the #23 can’t? It’s simple – this plane is designed with a step, often called a razee, at its rear. The wood is stepped down, and the cast iron frame is made to follow the step. This design increased the amount of space directly behind and under the cutter, making it possible to equip the plane with a tote. It was a very popular feature, making this transitional smoother one of the most commonly encoutered.
Check the cast iron frame, where it steps down for any signs of repairs or cracks. This area is prone to breakage, as is the overhang onto which the tote fastens.
11 replies so far
View Brandon's profile
Brandon
4152 posts in 3191 days
#1 posted 05-03-2012 07:14 PM
I have a No 35 plane as well. I call it my ugly duckling plane, because it sort of reminds me of a duck. I hope you enjoy yours!
-- "hold fast to that which is good"
View kaschimer's profile
kaschimer
89 posts in 2629 days
#2 posted 05-03-2012 08:48 PM
Hey! that looks like one I have as well. Just restored it to good working order
-- Steve, Michigan - "Every piece of work is a self portrait of the person who accomplished it - autograph your work with excellence!" - Author unknown
View SnowyRiver's profile
SnowyRiver
51457 posts in 3720 days
#3 posted 05-03-2012 08:51 PM
Great job…thats a nice looking plane.
-- Wayne - Plymouth MN
RussellAP
#4 posted 05-03-2012 08:52 PM
It’s a good planer. I sharpened the blade and took it apart and cleaned everything. Sanded the base down flat. It will curl some cigarette paper when it gets into a groove.
RussellAP
#5 posted 05-03-2012 08:55 PM
Lowering the handle does get more of your shoulder into the thrust, but the lower angle also allows for some chatter if it hits a snag. There is less downward pressure in favor of forward pressure. If the handle where just a bit higher it might improve it.
View Don W's profile
Don W
19050 posts in 2807 days
#6 posted 05-03-2012 09:16 PM
I have several transitionals including the 35. I don’t use them much. Glad to see it being used.
RussellAP
#7 posted 05-03-2012 09:18 PM
I have a bid on a Stanley No3 right now for $18. I need to get my blade sharpening set up.
View Bill White's profile
Bill White
5149 posts in 4200 days
#8 posted 05-03-2012 09:50 PM
I’m a plane nut, and would love to have one like that.
Get after it. Plane some wood and let us know how it works.
Bill
-- bill@magraphics.us
View james04's profile
james04
8 posts in 3614 days
#9 posted 05-03-2012 10:39 PM
Nice find.
View Dennisgrosen's profile
Dennisgrosen
10880 posts in 3355 days
#10 posted 05-03-2012 10:58 PM
great job on the refurb :-)
Dennis
View Martyroc's profile
Martyroc
2712 posts in 2545 days
#11 posted 05-04-2012 01:40 AM
Looks good Russ, treated right these last forever.
-- Martin ....always count the number of fingers you have before, and after using the saw.
