In need of cabinet finishing tips.
Forum topic by Philip "Pip" Storm posted 05-03-2012 12:33 PM 1098 views 0 times favorited 8 replies Add to Favorites Watch
View Philip "Pip" Storm's profile
Philip "Pip" Storm
130 posts in 2243 days
05-03-2012 12:33 PM
Topic tags/keywords: question trick tip resource maple finishing shaker
I’ve done plenty of projects requiring a good finish but this time around I’m building my own kitchen cabinets and I want to make sure I’m doing things right. I need any help you kind people are willing to share. I can tell you that they will be maple and maple plywood for exterior and birch plywood for interior. The maple will be stained with your basic wood stain with a satin finish. (dark, similar to chestnut and gunstock) The birch will be natural but finished for protection. What I’m looking for is steps, techniques, materials, tips, etc. So far, I’ve been testing different stains on scrap to get the color I want. I’ve gone so far as using pre stain conditioner on half the samples. I know that maple is a hardwood, so is still a good idea to treat with the pre stain? This is an example of some of the info I’m looking for. Thanks in advance.
-- Well, I'll be screwed, glued, and tattooed!
8 replies so far
View AJLastra's profile
AJLastra
87 posts in 2135 days
#1 posted 05-03-2012 01:38 PM
Pip,
Are you spraying your topcoats or brushing?
View Bill White's profile
Bill White
4859 posts in 3867 days
#2 posted 05-03-2012 02:32 PM
Maple will blotch like crazy, so I use a shellac (dewaxed) wash coat to seal, stain as desired, buff off any nibs, spray if ya can. You’ll get a smoother finish.
Bill
-- bill@magraphics.us
View TCCcabinetmaker's profile
TCCcabinetmaker
932 posts in 2262 days
#3 posted 05-03-2012 03:23 PM
maple does tend to blotch, this can be reduced dramatically with any pre-stain conditioner, and if you’re going for a dark color, you may want to test on a few scrap pieces to make sure the wood will take your stain, cause sometimes maple won’t take certain types of stains….
Last time I did a stained maple job with a dark stain on maple I used gemini’s annyline dyes and lacquer wiping stain, turned out awesome, only, the guy never finished his floors so I don’t have pictures of that job yet….. a year later….
-- The mark of a good carpenter is not how few mistakes he makes, but rather how well he fixes them.
116906 posts in 3484 days
#4 posted 05-03-2012 11:15 PM
I like Charles Neils Blotch control it makes hard wood and plywood come out with the same color, and General finishes stain/dye. I like to spray mine.
View rockindavan's profile
rockindavan
299 posts in 2543 days
#5 posted 05-03-2012 11:27 PM
Can’t help you much on the stain, but you should definitely spray the finish if you have an air compressor. If you don’t have a gun, harbor freight sells them for around $60. One of the very few HF tools I actually use, and I have had it for over 4 years. You will be much happier with a sprayed finish and takes a fraction of the time.
Philip "Pip" Storm
#6 posted 05-05-2012 12:15 PM
Thanks y’all. Hopefully with these great tips our cabinets will be something to admire and be proud of.
Philip "Pip" Storm
#7 posted 05-05-2012 12:15 PM
@ ajlastra, I plan on spraying.
View Fuzzy's profile
Fuzzy
298 posts in 3895 days
#8 posted 05-05-2012 02:17 PM
+1 on Charles Neil’s Blotch Control …
Spraying is my method of choice for a lacquer, but, for varnish/poly, I prefer to thin to an extreme, and wipe on several coats with an old t-shirt wrapped in a piece of pantyhose in tandem with a good brush for cleaning out corners & crevices.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
