Can anyone identify this lathe?
Forum topic by Scott Wilson posted 159 days ago 191 views 0 times favorited 12 replies Add to Favorites
View Scott Wilson's profile
Scott Wilson
20 posts in 293 days
159 days ago
Topic tags/keywords: question lathe rockwell delta turning
Hi guys. This picture is so small (I’m trying to figure out the camera on my new phone) that it may not be any help. I have a guy offering me this lathe for $200. I’m going back to his place next week to turn a piece or two to make sure it works. It is really heavy duty and I think it is a Rockwell Delta but I’m not sure. Everything has a SOLID coat of battleship gray paint to prevent rust that has been on there for years so I can’t find any numbers without stripping the paint. Assuming it works well, would this be worth $200?
Scott
-- Scott Wilson - Bear with me, I'm learning!
2081 posts in 558 days
159 days ago
Bad pic you should try again.
Scott Wilson
159 days ago
There we go!
teenagewoodworker
2135 posts in 305 days
159 days ago
any idea how old it is?
View tenontim's profile
tenontim
960 posts in 281 days
159 days ago
If the bed is made of cast iron, it could also be an old craftsman. My Dad had one that looked like this and it was as solid as a rock. I’m not a lathe expert, but I believe the lathes with the cast iron beds, rather than the tube types, are sturdier. I would pay $200 to have that old lathe back.
-- Tim -- http://tmuli.com
159 days ago
I’m guessing Oliver.
Scott Wilson
159 days ago
I’m not sure how old it is. But it is VERY solid. The bed and legs are cast iron. He says he is fairly certain it is a Delta but that is all he knows.
View Loren's profile
248 posts in 184 days
159 days ago
Looks like a Delta from the leg castings. I had a Rockwell lathe
with the same castings and it was very similar to this lathe.
Check the tool rest to make sure it lines up parallel to the work.
On my lathe the fit and finish wasn’t so great and the tool rest was
a little crooked.
It’s a decent lathe for spindle turning and other light work.
-- http://amherstcabinets.com - also a marketing consultant with expertise in direct response marketing for woodworking and online businesses - http://COPYMATCH.COM
Scott Wilson
158 days ago
Would it be OK for turning bowls?
158 days ago
Yes for bowls . No for big, crazy, unbalanced burls and other
outrageous forms.
I have a bunch of 6” faceplates for this 8 TPI lathes…
if you need some they are for sale.
6716 posts in 388 days
158 days ago
Scott, with a light frame like that one appears to be you would need to control the vibration. Either fix it to the floor or put some heavy items on it.
Scott Wilson
157 days ago
Like a couple of sandbags or something?
156 days ago
Sandbags are a great idea. i built a platform in the bottom of my lathe & filled it with hardwood blanks that I will one day use for turning.
Bookmark And Share This Page
