Which bandsaw to buy
Forum topic by majuvla posted 05-01-2012 02:17 PM 4150 views 0 times favorited 12 replies Add to Favorites Watch
View majuvla's profile
majuvla
12280 posts in 2863 days
05-01-2012 02:17 PM
Hello LJs,
I have one simple doubt about buying bandsaw.
There are two bandsaws on market here in Croatia with good prices and good caracteristics for amateurs.
ELEKTROMASCHINEN BSEm 750
0,75kW, max. cutting height 170mm, max cutting width 300mm – 500 $
and
ELEKTROMASCHINEN BSEm 1000
1,0 kW, max. cutting height 230mm, max cutting width 340mm – 610 $
Which one to buy? Is it worth it to pay extra 110 $? I soppose first option is enough for most bandsaw projects. I repeat I’m amateur, not profesional and don’t do woodworking for living -I just live for woodworking :-)
-- Ivan, Croatia, Wooddicted
12 replies so far
View waho6o9's profile
waho6o9
8189 posts in 2573 days
#1 posted 05-01-2012 02:22 PM
60mm extra cutting height and 40 mm extra cutting width is worth the $110.00 price difference in my book.
You won’t appreciate it until you need it and then you’ll be glad you purchased the upgrade. Good luck on your decision.
View John Ormsby's profile
John Ormsby
1285 posts in 3733 days
#2 posted 05-01-2012 02:25 PM
What will you be doing with the bandsaw? For example, resawing, cutting curves, etc. It is generally recommended to buy the biggest, heaviest, and best quality bandsaw one can afford and have a place for. The reason is that the bandsaw must be able to bring the blade to full tension. A weak frame is useless no matter what size saw. A more powerfull motor is also a good idea to have. The BSE 1000 would be the better choice if the frame is heavier.
-- Oldworld, Fair Oaks, Ca
majuvla
#3 posted 05-01-2012 02:53 PM
Thanks for advices.They are very usefull. I will keep them on mind when making final decision.
View jdmaher's profile
jdmaher
427 posts in 2575 days
#4 posted 05-01-2012 03:03 PM
You increase power and cutting height by 33% for a 22% increase in price, PLUS you get greater depth of cut. So, it IS worth the price difference.
Since these are not very big bandsaws, you’ll probably appreciate the extra cutting height and power right away. More is definitely better for smaller bandsaws.
-- Jim Maher, Illinois
majuvla
#5 posted 05-05-2012 01:16 PM
Thank you all LJs. I finally bought ELEKTRO Maschinen BSEm 1100. 1,1 kW, 23cm working height, 34cm working depth – real beuty!
View damir's profile
damir
1 post in 1976 days
#6 posted 12-23-2012 04:45 PM
Hi majuvla, while looking for reviews of BSEm 1100 on the web I stumbled on your post here. I’m thinking of buying it so if its not to much trouble to maybe give me some feedback and advice. I’m an amateur and would be using it mainly for resawing.
Split, Croatia
Thanks.
majuvla
#7 posted 12-24-2012 01:26 PM
Bok Damir,
Odgovorio sam ti u privatnoj poruci.
Pozdrav
Ivan
View smoq's profile
smoq
2 posts in 1846 days
#8 posted 05-03-2013 08:20 AM
Hi, I`m looking for reviews of BSEm 1100 also, so Ivan can you tell me your impressions of the saw, or someone who has it. I`m an amateur and I doubt if I buy BSEm 1100 or Metabo BAS swift. I need it for make toys and stuff for my kids and for other future projects.
Metabo BAS 260 swift – 0,35 kW, 32,5 kg, max. cutting height 100mm, max cutting width 245mm – 420$
Elektro maschinen BSEm 1100 – 1,1 kW, 84kg, max. cutting height 230mm, max cutting width 340mm – 600$
It is a big difference between these two saws but I am worried about the quality of Elektro maschinen and I can`t find any reviews of it. Metabo in this class costs 960$ (BAS 317) and it`s beyond of my budget.
Thanks!
Miro, Dugo Selo, Croatia
View dhazelton's profile
dhazelton
2767 posts in 2292 days
#9 posted 05-03-2013 12:32 PM
It looks just like a Rikon. Probably a fine machine.
majuvla
#10 posted 05-03-2013 01:58 PM
Bok Miro,
Bsem1100 je OK za amterski rad, ima dosta snage. S tri širine lista (6, 12 i 25 mm) možeš dosta toga napraviti. Naravno ne treba očekivati nemoguće i nadati se raspiljevanju klada u daske i sl. Ako radiš sitnije igračke za djecu, možda ti ne treba tako velika, ali nije loše imati rezervu mogućnosti ako zatreba. Možda nisam baš najsretniji kako gornji kotačići drže pilu ali što je tu je. Smatraj to definitivno amaterskim strojem i u tu svrhu se koristi. Dućan Elektromaschinen ti je u Samoboru pa se možeš telefonski informirati.
Pozdrav,
Ivan
View smoq's profile
smoq
#11 posted 05-03-2013 02:06 PM
Hvala na odgovoru!
Malo me je pokolebao ovaj post http://www.stolarskaradionica.com/forum/viewtopic.php?pid=43544#p43544
Znači uglavnom si zadovoljan
Da li se te tri pile dobiju sa strojem?
LP
majuvla
#12 posted 05-03-2013 07:22 PM
Ne, samo 12mm, ostale dvije posebno kupio, imaš ih u Bauhausu ili u njihovom dućanu u Samoboru.
Što se posta tiče, u pravu je, kao što sam rekao, nisam baš presretan s tim gornjim fiksatorom pile. Za krivocrtne rezove preporučam isključivo list 6mm, ostala dva eventualno za ravne ili blego zakrivljene. Nekakvo precizno ravno raspiljevanje ploha se ne može baš postići.
Pozdrav
Ivan
