Table saw arbor lubrication
Forum topic by TomFran posted 413 days ago 1567 views 0 times favorited 20 replies Add to Favorites Watch
View TomFran's profile
TomFran
2934 posts in 2191 days
413 days ago
Topic tags/keywords: tablesaw table saw bearing lube
My son just bought an old Sears table saw, and I believe the arbor bearings need some lubrication. I was wondering what would be the best product to use on this? Do any of you have a recommendation for arbor lube?
Thanks!
20 replies so far
View therookie's profile
therookie
887 posts in 1024 days
#1 posted 413 days ago
Well if the bearings are making noise and the saw is older then you might need to replace the bearings. Because most of the time the bearings are sealed and you cant lube them. Just my 2 cents.
-- http://aewoodworks.webs.com
View Greg The Cajun Box Sculptor's profile
3833 posts in 1505 days
#2 posted 413 days ago
Wouldn’t the bearing on a table saw motor be sealed to prevent dust?
-- Every step of any project should be considered your masterpiece if you want the finished product to reflect the quality of your work. http://www.FineArtBoxes.com
TomFran
#3 posted 413 days ago
The manual that came with the saw (yes, the manual was actually saved), says that the bearings can be and should be lubricated.
therookie
#4 posted 413 days ago
Then you must be talking about the outside surfaces of the bearing and i have never seen a saw with this… could you post a pic of the bearing?
View RetiredCoastie's profile
RetiredCoastie
999 posts in 1380 days
#5 posted 413 days ago
Since the manual calls for lubricant then it should specify what type of lubricant. If it doesn’t then you should use a dry spray lubricant.
-- www.thepatriotwoodworker.com Proud Supporter of Homes For Our Troops
TomFran
#6 posted 413 days ago
RetiredCoastie,
That’s true that the manual would specify what to use, but I was wondering if there is a better product for lubricating bearings today than there was 60 years ago when this saw was made.
View MedicKen's profile
MedicKen
1561 posts in 1659 days
#7 posted 413 days ago
Replace the bearings
View Sawkerf's profile
Sawkerf
1730 posts in 1265 days
#8 posted 413 days ago
Why do you think that the bearings need lubed? If they aren’t noisy or dragging, they’re probably fine. If you must lube them, I agree with Coastie about using a dry spray lubricant.
TomFran
#9 posted 413 days ago
OK, guys, thanks for the input. I do appreciate your advice!
MedicKen
#10 posted 413 days ago
The average life span of a sealed ball bearing is about 25 years. Being that the bearings are older than that I would replace them. If for nothing else peace of mind. The grease in the bearing, if there is any left, is going to be hard dried out and not able to lubricate anything. If you have to go through the hassle of removing the arbor why not just put new bearings in? To me, its a no brainer.
TomFran
#11 posted 413 days ago
Is it that easy to replace bearings in table saw arbors? Don’t they have to be pressed out with special tools?
And, are bearings for 60 year old saws easy to locate?
If it is something the average guy can do, and the bearings are available, then I agree wholeheartedly about replacement.
View GMman's profile
GMman
3885 posts in 1894 days
#12 posted 413 days ago
Sorry buddy but sears tools = junk
RetiredCoastie
#13 posted 413 days ago
A lot would depend on hours of operation, the environment in which the saw was exposed to and the most important thing would be run-out on the arbor. This can be checked very easily with a dial indicator or even a straight edge and feeler gauges. The old adage applies ” IF IT’S NOT BROKE DON’T FIX IT ”. Unless the saw has seen heavy use I would think it would be good to go.
TomFran
#14 posted 413 days ago
That is good advice. I’ll tell my son to check it for the run-out.
I believe he can get to the bearings without much problem, and so maybe some of the dry lubricant you mentioned in an earlier post might be all that’s necessary.
Thanks a bunch!
View Scot's profile
Scot
344 posts in 1593 days
#15 posted 413 days ago
Arbor bearings are easy to change but most people may not have a bearing press. But most auto shops do and some auto parts store do. Before I got my own bearing press I would just go to the local NAPA auto parts, I get my bearings there too, and they press them on for free.
I always get sealed bearing with metal side shields. They are lubed for life.
-- If the old masters had power tools, they would have used them. So get off your damn High Horse.
