| Forum topic by Texchappy | posted 384 days ago | 883 views | 0 times favorited | 9 replies | ![]() |
384 days ago |
What tools help the most with setting angles on dovetails with hand tools. I’ve seen on Roy Underhill that the traditional method is a square and bevel gauge. On Lie Nielsen that have a little gauge that looks really good. Any other things out there that help set the angles on them? -- Wood is not velveeta |
9 replies so far
#1 posted 384 days ago |
Texchappy—I have a set of the LN dovetail gauges … they are nice. However, all you really need is a combination square, a bevel gauge, and a marking gauge. The angles don’t need to be precise … just consistent. Many woodworkers just eyeball the angles to give it a look that says “Hand Crafted”. Some cut the tails first, then mark/cut the pins to match, which makes the angle pretty much irrelevant. —Gerry -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#2 posted 384 days ago |
Or, you can make your own. It’s easy peasy and all you need is some corner stock, mark off the proportions and file away. One’s for softwood and the other is for hardwood. They have ratios for the different dovetails, such as rise 5 inches and run 1 inch for example. |
#3 posted 375 days ago |
Hi Cheers -- Gossamer shavings just floating around the back yard….-Bandit |
#4 posted 375 days ago |
Texchappy, here’s what I use. I made my own dovetail marker (center of pic), my own mallet, and my own scribe (design borrowed from Steve Latta). You will need a set of SHARP chisels. I love the Shark dovetail saw. The tools of course are the easy part. -- I would drink a river of the kool aid before I took the smallest sip of the tea... |
#5 posted 375 days ago |
I have a little marker I made years ago similar to Johnnyblot’s. It’s just a little stick of walnut with a cut and filed piece of I mark the tails first because all the cuts are straight. I can |
#6 posted 374 days ago |
I’ve already blogged these home made dovetail squares http://lumberjocks.com/BigYin/blog/29514 http://www.youtube.com/watch?v=0dPb_5KFEYk&feature=related -- ... Never Apologise For Being Right ... |
#7 posted 357 days ago |
Just to add a bit more to this thread. -- Gossamer shavings just floating around the back yard….-Bandit |
#8 posted 357 days ago |
Why is the Liam Neison stuff so expensive it’s just bent brass.?Alistair -- excuse my typing as I have a form of parkinsons disease |
#9 posted 355 days ago |
Why is the Liam Neison stuff so expensive it’s just bent brass.?Alistair I agree. But do you own any? I agonised for days before I forked out £300 for my LN 5 1/2 plane. It is now my favourite tool. :-) -- Gossamer shavings just floating around the back yard….-Bandit |
| Forum | Topics |
Woodworking Skill Share
8790 |
Woodturning
220 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
78 |
Finishing
1529 |
3547 |
15767 |
Hand Tools
2034 |
Jigs & Fixtures
495 |
Wood & Lumber
2837 |
808 |
Focus on the Workspace
901 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6155 |
