Screw clamps
Forum topic by niki posted 04-28-2007 09:30 PM 1503 views 0 times favorited 3 replies Add to Favorites Watch
View niki's profile
niki
426 posts in 3955 days
04-28-2007 09:30 PM
Good day
That’s my version of screw clamps and I would like to share it with you.
As you noticed, all my jigs and fixers doesn’t look “Wow” but the do the job and this one is no exception.
I used 3/8” threaded rod.
I preferred to use wing nuts because sometimes I use the clamps to hold boards vertically, to work on them or to hold them during assembly and the knob would be on the way (I mean, the knob diameter is greater than the clamp thickness), the wing nut can be turned while the clamp is flat on the workbench as in the pic.
I use the wooden piece with the slot, normally to open the wing nut but it can be used also to apply more press than with the wing nut.
Usually, I use the wing nut and if I need very high pressure, I use the wrench.
Regards
niki
3 replies so far
View WayneC's profile
WayneC
13751 posts in 3972 days
#1 posted 04-29-2007 01:18 AM
These look quite useful. Another great jig. Thanks for sharing.
P. S. If your not going to write a book, you should at least submit some of them to the woodworking magazines.
View niki's profile
niki
#2 posted 04-29-2007 01:45 AM
Thank you Wayne
Wood Magazine “bought” from me the rights to publish the “45° cutting sled” and the “Triangle Copy and Past”, they have to publish it sometime within the next 4 months (the contract is for 6 months) but I will never know because I’m not subscribed to any WW magazine.
niki
WayneC
#3 posted 04-29-2007 01:47 AM
I’ll keep my eyes out, I normally pick up Wood Magazine.
