GFI circuit for Table Saw
Forum topic by rlamb007 posted 04-30-2012 03:12 PM 1875 views 0 times favorited 9 replies Add to Favorites Watch
View rlamb007's profile
rlamb007
72 posts in 2536 days
04-30-2012 03:12 PM
Topic tags/keywords: gfi table saw unisaw
Hello all,
I am now the proud owner of a 96 model 5hp Delta Unisaw.
It does need some work, but should clean up nicely.
I need to run a dedicated 220 circuit for it, and was wondering if anyone uses GFI when putting these circuits in.
Of course, a GFI would be nice, but the breakers for these are really expensive.
I was wondering if most people use GFI on their table saws? Also does anyone have any pros & cons for GFI (beside $$$) for the circuit breaker?
Thanks everyone.
-Rob in KY
9 replies so far
View Bill White's profile
Bill White
4930 posts in 3959 days
#1 posted 04-30-2012 03:17 PM
GFCI is not often used/required for a TS. Most often used when the recept is in proximity of a water feature (sink, tub, pool, etc.)
Bill
-- bill@magraphics.us
View MedicKen's profile
MedicKen
1615 posts in 3461 days
#2 posted 04-30-2012 03:21 PM
You may be required to install a GFCI if the saw is in the garage. I would check local codes and with an electrician. Here in the Peoples Republik of Kalifornia ANY garage circuit under 7’ MUST be GFCI.
rlamb007
#3 posted 04-30-2012 03:37 PM
Thanks Guys…I am leaning towards not installing. The saw will be operated in a dry area, but it will be on unfinished concrete slab floor. Maybe I can install one later, but we all know how that goes.
-Rob in Ky
View Sawkerf's profile
Sawkerf
1730 posts in 3067 days
#4 posted 04-30-2012 05:06 PM
GFI’s are used where proximity to water requires a more sensitive tripping mechanism. Table saws probably don’t need them.
View ChrisK's profile
ChrisK
1964 posts in 3080 days
#5 posted 04-30-2012 05:22 PM
Most areas require GFCI in garages since the floor can get wet. For $80 why not?
-- Chris K
View NathanAllen's profile
NathanAllen
376 posts in 3143 days
#6 posted 04-30-2012 07:32 PM
If in the garage or basement, better to be safe than sorry.
View Grandpa's profile
Grandpa
3259 posts in 2674 days
#7 posted 04-30-2012 08:21 PM
I believe the code says they are required in garages, unfinished basements, on kitchen counters, in bathrooms and withing 15 feet of a pool or spa (this includes whirlpool tubs). I used them in my steel shop with a concrete floor. I don’t think a bare concrete floor makes any difference. A basement is a basement. My bare shop floor looked like a garage to me so I used GFCI except on the 220V. It is not normally used on 220V unless it services a hot tub or something like that. Now with all that said local codes can require something different. Circuits that are for a dedicated appliance do not have to have GFCI. This is something like a refrigerator, freezer, washing machine or a sum pump in a basement. These trip so easily that motors can trip them and or a power outage will often trip one of them. Then you come home after a weekend away to find something green growing inside your refrigerator. Check locally first then proceed from there. I don’t think you will want one on a table saw because of the motor.
rlamb007
#8 posted 04-30-2012 08:33 PM
Well I do plan on wiring the saw directly (No plug) and everything will be contain in sheathing or conduit.
Pricing the Breaker looks like it going to be about ~$120
A little more information – the existing wired 220 outlets done by my electrician when this outside garage building was made were not GFCI. All other wall outlets are protected.
Grandpa
#9 posted 04-30-2012 08:44 PM
What you have is standard I believe. I am not an electrician but I try to keep up with things that concern me as a home inspector. Not saying I do keep up but those things show up in new homes (old wiring methods). Sometimes electricians don’t keep up with new codes either. Man, now I will get taken to the whipping post.
