dado setup
Forum topic by Mark Shultz posted 04-30-2012 03:42 AM 2721 views 0 times favorited 5 replies Add to Favorites Watch
View Mark Shultz's profile
Mark Shultz
105 posts in 2415 days
04-30-2012 03:42 AM
i bought a dado set used from a contractor. 3 of the spacer blades were waxed so i figured in good condition. when i took the wax off, the cutter tip (on top) was shorter than the opposing side (on bottom) – see picture. am i suppose to file down the bottom side? could it be that the tips were replaced an put on too short/low?
5 replies so far
View fussy's profile
fussy
980 posts in 3075 days
#1 posted 04-30-2012 04:01 AM
Don’t know what you bought, but I THINK the side opposing the cutter is there to limit the bite it can take to preventkick back. Any filing you do will sure unbalance the setting making for a VERY DANGEROUS SITUATION. If it runs smoothly, leave it alone. If it doesn’t, get rid of it.
Steve
View Sawkerf's profile
Sawkerf
1730 posts in 3093 days
#2 posted 04-30-2012 04:34 AM
Set it up and run a dado. If the bottom isn’t too rough, you’re ok.
Mark Shultz
#3 posted 04-30-2012 11:06 AM
Thanks guys. I have run it through the machine and it is not a smooth cut at all. the higher non cutting side provides friction and pushes the wood above the blade. one of the 4 inserts appears to have been filed down and that cutter runs smooth.
View knotscott's profile
knotscott
8056 posts in 3400 days
#4 posted 04-30-2012 11:53 AM
With those anti-kickback fingers sticking up above the teeth, there’s not much chance they’ll cut anything. Looks like it was resharpened repeatedly. It’s hard to imagine a competent sharpener doing that. Some of that material has got to go if that sets going to cut again. Here’s what the Freud Diablo DD208 dado set looks like:
Mark Shultz
#5 posted 05-04-2012 12:03 AM
new ones purchased!
